Author Topic: Carb secondary main jet  (Read 8868 times)
Re: Carb secondary main jet
« Reply #15 on: December 09, 2024, 08:26:29 AM »
That's how I did it. Just take care you don't damage the slides edge. I'm still thinking of a perfect bench sync. Think popsickle sticks that are 100% identical. The basic idea is leverage. Situate all four sticks under the slides front thus, that on closing the slides a tiny bit further, you cause the ends of the sticks to raise. Check the far ends of the sticks have reached the same height/angle and adjust if needed. I haven't tried it myself, but anyone is invited.
« Reply #16 on: December 09, 2024, 09:00:38 AM »
If you go for zero gap like I have on my 500 it was quite easy to see the slider twitch as it began to rise.
The down side for me was the main adjuster/stop  screw on the bracket ran out of thread on the adjuster totally compressing the spring on the screw. I ended up building up the alloy stop to compensate so the idle adjuster worked normally.
Offline Murf
« Reply #17 on: December 09, 2024, 07:22:33 PM »
Thanks, will go for engine side.
« Reply #18 on: December 09, 2024, 09:38:43 PM »
WD40 straw works fine with me and no damage to the slides  ;)
