Author Topic: Chassis plate - hammer in drive screw rivett size?  (Read 4905 times)
« on: December 06, 2024, 05:25:55 PM »
A member kindly sent me a few of the rivett things for re-attaching the chassis plate.
All used up now, anyone know what size they are & where I can get a few more from?
« Last Edit: December 06, 2024, 07:03:30 PM by McCabe-Thiele (Ted) »
Re: Chassis plate - hammer in drive screw rivett size?
« Reply #1 on: December 06, 2024, 07:19:45 PM »
I will try and remember Ted
« Reply #2 on: December 06, 2024, 07:22:54 PM »
Firm and pic should be attached BUT dont know the size you want Ted
« Reply #3 on: December 06, 2024, 08:10:20 PM »
My 400 & 500 were the same size so figured  the SD will be the same.
I think they are smaller than 3/16".
« Last Edit: December 06, 2024, 08:13:03 PM by McCabe-Thiele (Ted) »
« Reply #4 on: December 06, 2024, 09:18:44 PM »
Probabl are Ted, i didnt have time to look closely at the site, thats where mine came from and i had to order twice to get the correct size.
3/16 is the length the diameter is 00 or 2, which are number sizes one is 60 thou the other 80 thou ish or 1.5mm or 2 mm.
If you search on Accu web site for different sizes
« Last Edit: December 06, 2024, 09:25:59 PM by Bryanj »
Offline TezzerTel
« Reply #5 on: December 06, 2024, 09:31:40 PM »
I need a couple of these for my project too. I think I think I drilled the old ones out and used a 1.5mm drill (0.060"). I'll try and measure the holes tomorrow
« Reply #6 on: December 07, 2024, 10:58:13 AM »
Thanks for the link Bryan, I think I have a damaged new one that I kept with the correct sized drill bit, I was sent the rivetts by either you or Ken I think for my 400.
If I can find the damged one I'll try to measure the diameter and post it for reference as a starting point.
« Reply #7 on: December 07, 2024, 12:01:12 PM »
The drill bit has no markings, it measures 2.13 mm / 0.083" on the shank.
My damaged rivett looks like it was 4'5-5 mm long / diameter 2.15 ?
Looking at the Accu site the closest is nose diam 0.083"/2.108 mm, thread length 3/16" / 4.763 mm
Accu says thats No2 3/16", £1.80 for 12 with postage that's £8.46
https://www.accu.co.uk
« Last Edit: December 07, 2024, 12:55:36 PM by McCabe-Thiele (Ted) »
« Reply #8 on: December 07, 2024, 12:14:59 PM »
I'm sending you a PM.
« Reply #9 on: December 07, 2024, 01:55:12 PM »
Thats one of the two sizes i bought Ted, the other was smaller so good chance you are correct
Offline TezzerTel
« Reply #10 on: December 07, 2024, 04:24:14 PM »
My holes are about 0.078" so hopefully they will be nice and tight
« Reply #11 on: December 08, 2024, 05:23:51 PM »
The Rivets arrived today from Accu, they are No2.x 3/16" SS Hammer Dive round head. They are the right size for my SD.
