Author Topic: Lights not working  (Read 6123 times)
Offline Gmac
Lights not working
« on: December 07, 2024, 01:32:03 PM »
Just picked up a really nice '74 K4.
Seems to be mostly original, and most things work, except the head and tail lights, which was a surprise, given the overall condition of the bike, which I'd say is excellent
The switch illuminates the clocks, and the brake light works
Any obvious things to check on these, as it's my first CB750
Offline SteveW
Re: Lights not working
« Reply #1 on: December 07, 2024, 01:38:42 PM »
I’d start with the fuses.
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
Offline Gmac
« Reply #2 on: December 07, 2024, 01:48:43 PM »
I will do that. I just wondered if there was a 'go to' for this issue.
I don't have a wiring diagram, or manual, so going to have to work through them
« Reply #3 on: December 07, 2024, 01:56:31 PM »
Check fuse, bulbs and connections, in that order. All books and publications you need are in this link Guy. You can download and print them as well.
https://info.sohc.co.uk/
« Last Edit: December 07, 2024, 01:59:00 PM by Nurse Julie »
Offline Gmac
« Reply #4 on: December 07, 2024, 02:22:04 PM »
Many thanks  :)
Offline Mike_Berkshire
« Reply #5 on: December 09, 2024, 09:53:11 PM »
I had a similar issue on my 76 K2. It was corrosion between fuse and fuse clip
Offline ST1100
« Reply #6 on: December 10, 2024, 07:38:11 AM »
I'd trace & confirm with a multi-meter...
On a CX500 I'd worked on the fuses showed visually intact melting wires inside the glass, but no continuity...
STOC #637
Offline Skoti
« Reply #7 on: December 10, 2024, 08:50:32 AM »
Aye,
good advice above.
Had a problem with my F1 electrics,  bike stopped on the road, checked the fuses and all looked OK.
But eventually discovered the wire in the main fuse had melted through inside the end of the metal cap, and only at one side where you don't notice with just a quick visual inspection.
Anyhow later learned that this is often the case when you have poor intermittent connections through corrosion etc, and then just enough heat builds up to damage the fuse in this way.
Corrosion in the main engine block connector caused the issue for me.
Good luck
Skoti
« Last Edit: December 10, 2024, 09:17:12 AM by Skoti »
Skoti
1976 Honda CB750F1
Offline Gmac
« Reply #8 on: December 11, 2024, 05:18:26 PM »
There are signs of corrosion on some of the wires and connectors.
I plan to go through them, and replace some connectors, when I get the chance
Offline Gmac
« Reply #9 on: January 06, 2025, 10:57:16 AM »
It was just the main 5a headlight fuse. Luckily the original spare was still in it's holder. All sorted, and everything working now
« Last Edit: January 06, 2025, 11:06:13 AM by Gmac »
