Author Topic: 1980 CB100n  (Read 6551 times)
Re: 1980 CB100n
« Reply #15 on: December 16, 2024, 07:47:29 AM »
Thanks Ted.. a little way to go but it’s getting there
Graham
Psychologically that a good early boost to morale, be great to read your progress.
Offline GT Graham
Re: 1980 CB100n
« Reply #16 on: December 17, 2024, 06:38:03 PM »
I have had a go with the tank cleaning solution from Mad for bikes, 500ml that has sat in the tank for 10 hours, it’s removed some but not all, I have ordered some DEOX-C , I’m hoping that it will get rid of the remaining rust build up.
Hopefully the photo has attached
Re: 1980 CB100n
« Reply #17 on: December 17, 2024, 08:53:14 PM »
I used the now very expensive Evaporust. My 400 tank had petrol in it that had stood for over 10 years so was pretty bad inside.
I had two distinct steps to clean the tank interior.
1. Mechanical removal of the worst of the rust and gunk inside using what was gravel & with diesel as the lubricant.
2. Wash out Diesel then add Evaporust, rotating tank as needed. Left for a couple of days. New Evaporust for final clean.
Lots of alternatives such as Citric Acid. Time consuming process
