Author Topic: ignition  (Read 9713 times)
Offline Martin6
Re: ignition
« Reply #15 on: December 11, 2024, 01:26:21 PM »
Morala.
As a starter(pardon the pun), I recommend you remove and open the starter solenoid. Check to make sure the post moves freely and that the horizontal copper bar is not fused across the solenoid contact posts. If necessary you can flip the bar over to provide a nice set of fresh contacts.
Offline Morala
Re: ignition
« Reply #16 on: December 11, 2024, 08:18:07 PM »
thanks for all your help,tried the bike today started without any problem so will leave it to see if the problem happens again,wont be using the bike over the winter so gives me time to keep an eye on it thanks again for all your advice.
Online Bryanj
Re: ignition
« Reply #17 on: December 11, 2024, 08:24:52 PM »
If the solenoid stuck once it will again so probably worth changing, they aint expensive
Re: ignition
« Reply #18 on: December 11, 2024, 08:27:00 PM »
Personally, I think  that's a problem that needs sorting, not ignoring in the forlorn hope it will go away. For the relatively modest cost involved I would start by replacing the solenoid.
You stated it went on to flatten the battery with the ignition off, that could end up as a damaged battery or a burnt out starter motor as collateral damage, plus a theoretical wiring loom issue caused by the current flow on earthed circuits
« Last Edit: December 11, 2024, 08:33:06 PM by McCabe-Thiele (Ted) »
Re: ignition
« Reply #19 on: December 11, 2024, 10:06:44 PM »
TBH it’s a pretty quick job to split the solenoid and clean up the contacts. It’s probably a good investment in your time to avoid a potentially expensive collateral damage situation….just saying.
Offline Morala
Re: ignition
« Reply #20 on: December 11, 2024, 10:43:08 PM »
cheers lads a new solenoid it is then
Re: ignition
« Reply #21 on: December 12, 2024, 07:28:10 AM »
Are you sure you can’t fix the existing one? They come apart really easily. The problem is probably the copper contact bar in the solenoid, which is readily accessible and easily cleaned up. Assuming of course it’s an original relay/solenoid.
« Last Edit: December 12, 2024, 07:30:33 AM by Sesman »
Offline Morala
Re: ignition
« Reply #22 on: December 12, 2024, 01:28:52 PM »
just an update on the solenoid problem, when i started to remove the solenoid i found one of the contact securing nuts was very loose could this be the problem, i have only got the bike so still learning the ins and outs of it cheers.
Re: ignition
« Reply #23 on: December 12, 2024, 02:13:49 PM »
I doubt it, if as you have stated the starter continued to crank over with the ignition off until the battery had run down, that could not be caused by a loose terminal.
Offline Morala
Re: ignition
« Reply #24 on: December 12, 2024, 03:06:59 PM »
no problem, will replace solenoid and again thanks for all the advice
Re: ignition
« Reply #25 on: December 12, 2024, 07:12:46 PM »
It could have created arcing on the solenoid contacts within the unit causing the copper contact bar to temporarily fuse to the contact posts. 110A starting current and IsquaredR would create considerable heat. I’m not convinced a new solenoid would be required. I’d suggest opening the solenoid to check the internal contact bar before spending your money. Your choice of course.
« Last Edit: December 12, 2024, 07:15:40 PM by Sesman »
Re: ignition
« Reply #26 on: December 12, 2024, 07:37:26 PM »
Can the solenoids be unscrewed Phil or is it some sort of crimping, can't say I've ever taken one to bits ?
Online Bryanj
Re: ignition
« Reply #27 on: December 12, 2024, 08:40:17 PM »
Bit of both on originals Ted
Re: ignition
« Reply #28 on: December 12, 2024, 10:20:04 PM »
My 1977 550 F2 original solenoid contacts canister and coil unit are joined together using two screws and a simple tongue and recess arrangement. I’ll try to get a picture tomorrow, as long as I don’t have to remove it to do so. Original units are very, very unsophisticated and all the better for it.
« Last Edit: December 12, 2024, 11:16:48 PM by Sesman »
Offline Morala
Re: ignition
« Reply #29 on: December 15, 2024, 12:01:05 AM »
another update, i removed the solenoid and cleaned all the contacts, checked the wiring refitted the unit, will keep an eye on it over the winter cheers for all your help again.
