Author Topic: ignition  (Read 3704 times)
Re: ignition
« Reply #30 on: December 15, 2024, 04:40:35 AM »
Did you take it apart and clean the internal contacts?
Offline Morala
Re: ignition
« Reply #31 on: December 16, 2024, 07:50:33 PM »
Hi Bryanj, yes i cleaned the contacts and checked the wiring then fitted the unit back in, hope everything works ok cheers.
Offline Morala
Re: ignition
« Reply #32 on: January 02, 2025, 10:52:16 PM »
just an update re. ignition, after i cleaned the contacts and re fitted the unit it seems to be working ok but will keep an eye on it to be sure, again thanks for all your advice and help.
