Author Topic: A cam chain splitter  (Read 10158 times)
Offline nairb
« on: December 21, 2024, 08:18:20 AM »
Rather sadly, I have to take the cl450 engine apart.  I hate taking a factory finish engine apart, but it needs to be investigated.  It's those bits that have dropped out the bottom during an oil change which has made this necessary.
I thought I would be able to get away with leaving the cam chain in one piece.  I have done this with the cb550 and the cb360 (I think).  2-stroke engines are so simple..... (except the re5).
So, the day has arrived when I finally need to invest in a cam chain splitter.
Anybody found one on the bayE which is suitable.  I will get a new cam chain from DS anyway, so I could cut it off if necessary.
Can a splitter also be used to put the chain rivet in, on a new chain.  I suppose that's a different tool.
I dont want to use a split link on a cam chain.!!
Ta Nairb
« Last Edit: December 21, 2024, 02:09:38 PM by nairb »
cb550k3, cl450k5, re5m, xs650xs2, mt500, kettle, gt550 x2, gt380 Kz750 twin, cb360K0 and an old working bicycle
Offline Skoti
Re: A cam chain splitter
« Reply #1 on: December 21, 2024, 08:32:38 AM »
Anybody found on the bayE which is suitable.  I will get a new one from DS anyway, so I could cut it off if necessary.
Can a splitter be used to put the chain rivet in.on a new chain.  I suppose that's a different tool.
Ta Nairb
As you're going to fit a new chain, why not just grind the rivet pins flush with an angle grinder and remove the link.
If you're handy with a hammer and punch it's possible to rivet the new chain in place without a special tool, although you'll probably need a helper to hold a hammer on the opposite side of the rivet link to counter the hammer blow impact.
Good luck
Skoti
Skoti
1976 Honda CB750F1
« Reply #2 on: December 21, 2024, 04:10:44 PM »
Some internal chains have same form as kart racing final drive type chains
For which you can buy these https://www.demon-tweeks.com/demon-tweeks-kart-chain-splitter-219-pitch-kpuk219-splitter/ if they do match.
« Reply #3 on: December 21, 2024, 07:55:39 PM »
Most splitters will re rivet BUT the 450 is awkward on space so it would need to be a suitable one, you could pm Ash and ask his advice or i believe there is a forum dedicated to the 450 dohc.
I think you can remove the lower case without splitting off the head and barrels to inspect lower end
