Author Topic: engine revs  (Read 5955 times)
Re: engine revs
« Reply #15 on: December 25, 2024, 10:42:55 AM »
I would say not. My carbs were well and truly plugged with varnish and no amount of carb cleaner would clear them. I had to resort to using an ultrasonic cleaner used in conjunction with Allan’s solution at 60deg C along with some judicious probing with a guitar string in the idle jets and passages. Result….perfect idling and throttle response. This thing can actually tick over at around 500 rpm!!!
Re: engine revs
« Reply #16 on: December 25, 2024, 10:58:12 AM »
They can but by christ the primary rattles if the carbs are slightly out, i always used900 to 1000
Offline DomP
Re: engine revs
« Reply #17 on: December 25, 2024, 12:51:51 PM »
Regarding the passages, I've never really known which ones should exit where to know I've definitely cleared them.  Some are obviously blanked off, is there a diagram anywhere detailing the routes?
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Re: engine revs
« Reply #18 on: December 25, 2024, 04:21:28 PM »
I know. I was simply suggesting that proof of a healthy, well set up motor is its ability to tick-over at very low revs. My optimal idle speed  (quietest) is actually 1100rpm.
Re: engine revs
« Reply #19 on: December 25, 2024, 04:23:36 PM »
Trick here is to use your fingers, blocking off two outlets of the three at any one time. I’m sure there is a diagram somewhere. I used it to identify the circuits in order to force fluid through the passages.
« Last Edit: December 25, 2024, 04:26:42 PM by Sesman »
Re: engine revs
« Reply #20 on: December 26, 2024, 12:03:17 PM »
Maybe this helps. From 08:30 on in: https://www.youtube.com/watch?v=iXD7F4q72M4
« Last Edit: December 26, 2024, 12:46:14 PM by deltarider »
