Author Topic: Advance Retard Mech removal.  (Read 3352 times)
Offline Mike_Berkshire
« on: January 02, 2025, 03:57:01 PM »
Hi all and a Happy New Year to you!
The next task for my '76 K2 550 is to check, remove and clean the advance retard mechanism. This has not been removed since I got the bike and in all likelihood has not been removed since 1976. To first take off the ignition points plate it looks as if I hold the larger nut still whilst undoing the 10mm bolt that screws into the end of the crankshaft. Before doing this I thought I would check with those that have done this before if there are any hints/tips for doing this as its clear that any cockup in the process could have dire consequences.
Any suggestions would be very much appreciated.
Cheers, Mike
Re: Advance Retard Mech removal.
« Reply #1 on: January 02, 2025, 04:00:43 PM »
It's that easy
« Reply #2 on: January 02, 2025, 04:11:24 PM »
I would add, that if you dismantle the advance and retard itself by removing the springs, mark the two parts so you do not assemble it 180 deg out.
« Reply #3 on: January 02, 2025, 08:06:54 PM »
Thanks guys. AR mech now off and seems to be in good nick. No stickiness
« Reply #4 on: January 02, 2025, 09:23:04 PM »
If it works as it should, which is easy to check, I'd leave it alone. It doesn't need maintenance.
