Author Topic: New sponsor here?  (Read 7644 times)
New sponsor here?
« on: January 10, 2025, 07:21:43 PM »
Just noticed our new site sponsor, does this mean the members discount has gone Julie?
I'm after a couple of screws for the inlet manifold guage vacuum point on my 400NA, not sure if they are the same thread length as the 400/4?
Re: New sponsor here?
« Reply #1 on: January 10, 2025, 07:42:47 PM »
Hi Ted.
Nothing has changed Ted, still 10% discount and post at cost to forum members if they PM me.
I've no idea if those screws are the same, have you got a part number?
« Reply #2 on: January 10, 2025, 07:44:24 PM »
They are not Ted, 400n is 2mm longer in thread length, 5x8 as opposed to 5x6, I’ll send you a couple of stainless steel ones foc, I’ll put them in the Drexel flexible drive box when I send that.
« Reply #3 on: January 10, 2025, 07:56:30 PM »
Welcome back Ken!👍
« Reply #4 on: January 10, 2025, 08:19:35 PM »
Thanks Ken,  the screws are M5 x 8 mm - I think p/n 93500-0508-OH.
I don't see the length as too critical as it's just blocking up a hole!
« Reply #5 on: January 10, 2025, 09:08:04 PM »
Weirdly the length is critical, too long and they protrude into the air/fuel flow to the cylinder, this can cause turbulence and affect the way it fires. One of the tricks Mark Paris (Hondaman) advises is to trim the screws until they are flush with the manifold. The 500/550 suffer with this problem.
Saved my first post for you Ted, my comeback champion  :) :)
« Reply #6 on: January 10, 2025, 09:21:01 PM »
You have been missed Ken, welcome back.
PS obviously if too long it would mess up the air flow, not sure if too short would create a venturi vacuum, thus turbulence.!,😁😁😁
Online Sesman
« Reply #7 on: January 10, 2025, 11:10:55 PM »
Welcome back, Ken. You have been missed.😉
« Reply #8 on: January 10, 2025, 11:51:31 PM »
I fit them, see if they protrude, trim them and then use a Dremel to shape them to the airflow, on the 500/550 I use those discs to smooth out the extremely rough interior of the inlet manifold to aid a smooth air flow, not too smooth, you want a very small amount of turbulence to assist the mixing of the air/fuel. The faster you can get the fuel to the cylinder the more power the engine makes, it’s only a few bhp but they all add up.
Cheers Phil and all those who messaged me.
« Reply #9 on: January 11, 2025, 08:43:22 AM »
Welcome back to the forum Ken, your knowledge and contribution is valuable to the others on here.
Offline Rozabikes Tim
« Reply #10 on: January 11, 2025, 08:48:33 AM »
Good to see you back Ken. You were missed.
Offline hondarc166
« Reply #11 on: January 11, 2025, 04:59:00 PM »
welcome bake ken :)
Offline DomP
« Reply #12 on: January 11, 2025, 06:14:16 PM »
Hi Ken, I knew you'd be back!!
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Online Sesman
« Reply #13 on: January 11, 2025, 07:53:53 PM »
Hey, Ken.
To save me searching, can you remind me of who can supply me with a 3 line brake pipe solution for my 550. I’m using the traditional/original solid pipes to the calipers. Was it Hel?
« Reply #14 on: January 11, 2025, 08:48:02 PM »
I ordered mine from Hel, I’m still using the metal hard line from the caliper. Not fitted them yet but they look ok, my last ones went straight into the caliper and did away with the hard line part. Think they were Goodridge.
