Author Topic: Realising what a good site sohc UK is!  (Read 1700 times)
« on: January 20, 2025, 06:13:28 PM »
I've been asking about potential wheel interchangability between the CB400NA, & 250NA  Superdream models,   plus the NB & NC variants.
Whilst I have had some advice it's been sufficiently vague enough to be almost useless, long live this site.
Offline ozzybud
Re: Realising what a good site sohc UK is!
« Reply #1 on: January 20, 2025, 07:02:47 PM »
It's not a SOHC? .Lol
All the experts on here are SOHC experts!
Maybe there is a site for those bikes
1976 Z50 PARAKEET YELLOW
1970 CT70 CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVERA BLUE
1973 CB350F FLAKE MATADOR RED
1974 CB350F GLORY BLUE BLACK
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
« Reply #2 on: January 20, 2025, 07:22:38 PM »
IIRC Ted, the NB went to reverse black comstars and the NC went to gold reverse comstars, just like the 900FA, FB and FC did.
« Reply #3 on: January 20, 2025, 07:28:31 PM »
I'm pretty sure you are right Ken, do the 250NB black Comstars  wheels fit a 400 NA ?
« Reply #4 on: January 20, 2025, 07:49:22 PM »
Misunderstood your post, what sort of camshaft does the CB400N have, it's a single overhead camshaft engine that operates all three valves?
The two Superdream sites added together do not hold a candle to this site, that was the point I was making
GM called their old ohc engines cam in head engines as the camshaft did not operate directly on the valves.
« Last Edit: January 20, 2025, 09:21:15 PM by McCabe-Thiele (Ted) »
« Reply #5 on: January 20, 2025, 09:46:53 PM »
Ted. As an educated? Guess if the brake shoes are the same the wheels will fit
Offline ozzybud
« Reply #6 on: January 21, 2025, 02:22:31 AM »
Ok I guess we need to change the wording on this site. I thought both this site and the US site dealt with SOHC 4 cylinder bikes as the header statement says...
It's all good as I wasn't sure if you were kidding or serious?
This is the UK home of all things to do with classic SOHC 4 cylinder Honda motorcycles from the (late) 60s through to the (early) 80s
« Reply #7 on: January 21, 2025, 03:56:51 AM »
In my defence there is a section here for sohc singles & twins for those of us short of a few cylinders, nice wording. lol
I know the Superdream is probably considered a poor relation compared to the 400/4.
« Last Edit: January 21, 2025, 03:58:29 AM by McCabe-Thiele (Ted) »
« Reply #8 on: January 21, 2025, 04:00:57 AM »
You may well be right Ken, at the moment the Real SD site seem to be saying that the black reverse Comstars went on the 250NC,
the gold reverse Comstars went on the 400NC.
« Reply #9 on: January 21, 2025, 04:09:29 AM »
I've been checking if the rear wheel spacers are the same, I'll look into the brake shoes as well.
As extra confusion the 250's I've seen had single front disc brakes whereas the 400 had twins.
Not sure if you can fit a second disc on a 250 on the same wheel.
Owners seem to say the twin disc brakes on the SD are not great, I see the front caiipers changed in later models.
I'm still learning how to drive the parts book I downloaded, I might do better using the csmnl site.
Hopefully the rear wheel does not need replacing so I can stick with what I have.
