Author Topic: Electrical connections.  (Read 2952 times)
« on: January 23, 2025, 09:49:58 AM »
Just wondered what the consensus off opinion on treating block connectors before connecting them up.  Better to leave clean and dry or maybe a squirt of WD? How do you treat yours?
Re: Electrical connections.
« Reply #1 on: January 23, 2025, 10:01:54 AM »
When I've replaced block connectors after cleaning contacts I clip them together then squirt some WD40 on them in the hope of driving out any moisture, I have run out of contact cleaner that might be better. Bullet connectors I just do dry.
Not saying it's a good idea, just being honest.
« Reply #2 on: January 23, 2025, 10:22:10 AM »
Just wondered Ted with them being quite exposed to the moisture road spray etc.
« Reply #3 on: January 23, 2025, 10:24:37 AM »
In my head I think after it stops raining then they blow dry!😃
« Reply #4 on: January 23, 2025, 10:28:06 AM »
Probably do indeed. I’m not generally getting my connections wet, but do usually get an annual soaking getting caught out.😜
« Reply #5 on: January 23, 2025, 11:11:59 AM »
Silicone grease onto all the contact /voids.
Doesn't conduct, so no benefits in that direction, but with almost complete absence of any moisture during use, they stay in pristine condition.
It won't affect plastics or rubber either.
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
« Reply #6 on: January 23, 2025, 11:33:30 AM »
The 6.3mm terminals/connectors are very robust, just keep them clean & dry.
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
Offline ST1100
« Reply #7 on: January 23, 2025, 01:18:54 PM »
I treat all electrical connectors with a whiff of ACF-50... spray, or distribute a small amount with a Q-tip, whatever the situation requires...
https://www.acf-50.eu/acf-50
Brilliant results...
Handlebar switch-pods, ignition lock switch-plates, bullet- or multi pin connectors, relay & bulb sockets... (even the PCB inside the face-plate of the Sony stereo on my ST1100...)
STOC #637
Offline Skoti
« Reply #8 on: January 23, 2025, 06:10:07 PM »
Aye,
I agree.
Clean and dry is best, spray stuff attracts unwanted dust and dirt to stick.
Skoti
1976 Honda CB750F1
« Reply #9 on: January 23, 2025, 07:18:23 PM »
When I cleaned up my wiring harnes all the connectors were cleaned and then coated with dielectric (silicone) grease, never had a problem.
