Author Topic: Carb rubber clamps  (Read 4934 times)
Offline TezzerTel
Carb rubber clamps
« on: January 23, 2025, 08:18:20 PM »
This has possibly been discussed before 🫣 but what are people's preferences when it comes to carb rubbers clamps? The original type or 'jubilee clip' type ?
Re: Carb rubber clamps
« Reply #1 on: January 23, 2025, 08:31:44 PM »
Personally speaking…original.
« Reply #2 on: January 23, 2025, 08:37:02 PM »
You have to be carefull with jubilee as most are too wide, i did find some stainless narrow ones on ebay, if i can find a number i will post it
« Reply #3 on: January 23, 2025, 10:41:04 PM »
« Reply #5 on: January 24, 2025, 12:13:44 AM »
Not from the firm i used but same things
Offline Skoti
« Reply #6 on: January 24, 2025, 07:00:22 AM »
Got to be careful with some of those after market hose clips, they have sharp edges that could damage the rubber manifold stubs if over tightened.
The Norma brand seem to have the turned up edges similar to the OE Honda ones tho.
Although I use only the proper Honda ones.
Skoti
1976 Honda CB750F1
Offline Skoti
« Reply #7 on: January 24, 2025, 07:05:54 AM »
Or these… https://4into1.com/cb500k2-500-four-1973/?_bc_fsnf=1&Main+Category=Air+%2F+Fuel
Just seen this, those clips look ok and have the turned up edges I mentioned on my post above.
Skoti
1976 Honda CB750F1
« Reply #8 on: January 24, 2025, 12:58:39 PM »
I wouldn't recommend 4 into 1 to anyone, their reputation for selling crap is worldwide.
« Reply #9 on: January 24, 2025, 01:08:09 PM »
To be fair, I bought some clips and they were fine.
I couldn’t comment on other products.
« Reply #10 on: January 24, 2025, 01:20:25 PM »
Don't buy any rubber products or carb products, both are very cheap, poorly made and cause problems. USA site is full of comments regarding them.
Offline TezzerTel
« Reply #11 on: January 24, 2025, 01:47:46 PM »
I was asking more on what style of clamp we prefer and possibly why you prefer that type. I've just taken some jubilee type off mine to go back to the original type but not sure if I'm doing right
« Reply #12 on: January 24, 2025, 01:49:58 PM »
Hi, Tezzer.
I’d say whatever takes your fancy as long as they fir properly and don’t damage the rubbers.
Me, I prefer to run with what the original manufacturer used.
« Reply #13 on: January 24, 2025, 01:59:49 PM »
I prefer stainless jubilee clips myself, just because they don't rust, they are also able to exert more pressure as I've had standard clips where the ears are hard up against each other so are at the limit of sealing power. Also how many have had the screw rust into place and the whole clip bending sideways when you try and remove the clip.
However the downside is that they can mark the rubber, it's only visible though when you remove the clip.
Offline Seabeowner
« Reply #14 on: January 24, 2025, 07:20:44 PM »
For the rubbers between the inlet manifold I'd use stainless bands. For the rubbers between the carbs and the airbox are softer and more easily damaged so I like to stick to original bands.
https://www.cmsnl.com/products/band-44-airc-con_9501844250/
Bad enough but DSS are silly price.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
