Author Topic: Sprocket nuts seized  (Read 5155 times)
Offline Mike_Berkshire
« on: February 09, 2025, 02:58:26 PM »
Hi all. Front hub polished and now on to rear hub. I need to replace the worn rear sprocket so thought I would remove the old one before I start polishing. I have flattened the tab washers, given the studs/nuts a good squirt of penetrating oil and left them to soak. However all 4 nuts seem seized solid. Before I resort to more destructive methods of removing the nuts are there any tricks/techniques to try? ‘76 550 K2
Re: Sprocket nuts seized
« Reply #1 on: February 09, 2025, 03:01:28 PM »
Heat
Rattle gun
More penetrating oil,diesel is very good
Apply all over the next week
Unless your in a rush
« Reply #2 on: February 09, 2025, 03:47:06 PM »
Bit of heat in case somebody’s been in there with thread lock?
Offline Honda enthusiast
« Reply #3 on: February 09, 2025, 04:25:26 PM »
loctite freeze and release is worth a try, Mike..not cheap at £20 a can but it freed my wheel nuts on a 1972 Massey 165
« Reply #4 on: February 09, 2025, 07:16:19 PM »
I used a cordless Impact Driver as I'm old (77 soon) & weak, one of my better buys a few years ago that I bought to undo car wheel bolts.
« Reply #5 on: February 09, 2025, 07:21:25 PM »
I have done the same
It's a Chinese Makita copy,
About £25
Plus the same for a battery and charger
I find it OK for hobby use,
Aliexpress, lots of fun toys you never realised you wanted!!!
« Reply #6 on: February 09, 2025, 08:28:23 PM »
Is it just the hub assembly and minus the spokes rim etc ?
If so, you'll probably need to anchor it with a chain to get adequate leverage on them.
As above though, a rattle gun can help you. I bought a makita 1/2 drive one that's beennreslly useful, along with common batteries we've got with other tools.
« Reply #7 on: February 09, 2025, 08:41:56 PM »
A good heating with a gas torch and a bash with the trusty impact driver and the job is done.
The nuts are a bit chewed up; do I need special nuts as replacements or are any nuts ok? The ones I have seen online all seem to be flanged and some are nyloc.
« Reply #8 on: February 09, 2025, 09:18:28 PM »
They are thinner than normal
