Author Topic: CB360 Ignition Timing Headache  (Read 7340 times)
Offline Craizeehair
« on: February 16, 2025, 06:09:20 PM »
I’m hoping I can get some advice regarding the ignition timing on this bike.
I recently stripped the engine and, cleaned everything and gave it a lick of paint, reassembled and now have the engine back in the bike and I am now trying to get it back up and running.
A week or two ago I set the valve clearances, static timing etc and the bike started first time and seemed pretty good. I started to balance the carbs and the bike started running rough and died on me. I wasn’t sure why but when I started to check everything from the start again I found the bolt that holds the spark advancer that goes into the end of the cam had come loose and out. I fitted this back nice and snug and did the ignition timing again. I’m now only firing on the left side, I have taken the carbs off three times and am now happy these are ok.
What does happen though is every time I redo the ignition timing and start the bike and still only fire on one side, I check the ignition timing and it’s way out again, I’ve tried this three times now and every time  after the bike has run for a few minutes, I check the ignition timing and it’s nowhere near again.
Any ideas of what could be happening or what I might have messed up? I can get it right on the mark but it just won’t stay there?
Re: CB360 Ignition Timing Headache
« Reply #1 on: February 16, 2025, 07:53:24 PM »
Things i would check
Advance unit has the peg on the back fitting properly in cam, or might be peg on cam fitting in advance unit, it has been 50 years since i worked on one
Advance unit has decent springs returning points cam properly
Has the rotor on crank started to come apart and/or keyway sheared
Did points get damaged when advancer came loose
EDIT  there is a pin 30905216000 shown on parts at cmsnl that goes in cam to locate advancer, damage there would cause your problem
« Last Edit: February 16, 2025, 07:56:43 PM by Bryanj »
Offline Craizeehair
« Reply #2 on: February 16, 2025, 08:18:24 PM »
Thank you again Bryan, I will get back in the shed this week and check these. I’ve looked on CMSNL but can’t see it on the parts diagram, sorry to be a pain but would there be any chance you could let me know if it’s on this diagram or let me know the key number so I can see it on the diagram?
« Reply #3 on: February 16, 2025, 09:11:59 PM »
No its on the othe engine diagram with camshaft and valves, no 181 i think
Offline Craizeehair
« Reply #4 on: February 16, 2025, 09:23:12 PM »
Thank you
