Author Topic: CB500K2 four 1975 timing chain tensioner fitment  (Read 9021 times)
Offline martin_uk
« on: February 19, 2025, 05:27:38 PM »
Continuing the engine reassembly find pressure needs to be applied to top of tensioner to fit top bolt through head.
Is this normal ?
I didnt notice a locator in crank case for bottom of tensioner and concerned that may have missed.
Now difficult to see with barrels and head fitted.
Can you remove and refit tensioner without removing head? (camshaft not fitted)
Martin
1977 CB750F1
1978 CB750F1
1975 CB500K3
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Re: CB500K2 four 1975 timing chain tensioner fitment
« Reply #1 on: February 19, 2025, 05:35:32 PM »
Can you look up from the sump end?
« Last Edit: February 19, 2025, 06:01:41 PM by McCabe-Thiele (Ted) »
« Reply #2 on: February 19, 2025, 05:58:46 PM »
Remove sump and you can see if it's in the slot. Sounds like it's not. A lot of tensioners get bent due to misfitting, most get damaged by the primary chain which runs right by the side of it when this happens.
Offline martin_uk
« Reply #3 on: February 19, 2025, 06:03:04 PM »
Thanks guys will check
1977 CB750F1
1978 CB750F1
1975 CB500K3
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
« Reply #4 on: February 19, 2025, 06:55:26 PM »
Good shout, sump off and bottom of tensioner out of recess.
Even with tensioner compressed not able to angle in enough as up against inside of head.
Will try again tomorrow, but suspect head may need to come off to get correct angle unless anyone has a special technique?
1977 CB750F1
1978 CB750F1
1975 CB500K3
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
« Reply #5 on: February 19, 2025, 08:02:59 PM »
Most require the head off again. Lift the barrels an inch or so, compress the tensioner by hand and lock it off with the locknut, Then lower the barrels whilst making sure the end of the tensioner goes into the slot. Check the tensioner body isn't bent, a lot are. It should look straight to the eye. If it's bent straighten it.
« Reply #6 on: February 19, 2025, 08:54:11 PM »
Might be of help? This is a picture of mine, you can clearly see where the tensioner end was! Now sitting in the correct position.
Offline martin_uk
« Reply #7 on: February 20, 2025, 08:39:58 AM »
Thats great really helps
1977 CB750F1
1978 CB750F1
1975 CB500K3
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
« Reply #8 on: February 20, 2025, 08:42:20 AM »
Thanks, it really helps
1977 CB750F1
1978 CB750F1
1975 CB500K3
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
« Reply #9 on: February 22, 2025, 12:40:31 PM »
Unfortunately, as others have commented, can't fit the tensioner into locator with the head on.
The problem is the adjuster stud holds tensioner too far over before it can be inserted to bottom fixing.
Will try with head off but suspect barrels will need to be lifted as suggested to insert adjuster stud before lowering.
1977 CB750F1
1978 CB750F1
1975 CB500K3
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
« Reply #10 on: February 23, 2025, 12:01:12 PM »
Thanks Oddjob.
This was the only way to do it.
1977 CB750F1
1978 CB750F1
1975 CB500K3
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
