Author Topic: Something I can't find  (Read 9602 times)
Offline Athame57
« on: March 12, 2025, 01:45:16 AM »
Can someone help me find the part numbers for the screw and locknut arrowed in the image supplied? I went to the CMSL site to find it on their exploded plan of the carb assembly so I could pull up the part number to put in the DSS search box but I can't find them on that plan. :o I want to get these replaced because mine are just too rusty to rescue anymore.
1978 CB400F2 named Elen.
Offline Skoti
Re: Something I can't find
« Reply #1 on: March 12, 2025, 07:18:00 AM »
That looks like a non original Honda set screw with a slotted head like that.
If you want something that looks original then probably a JIS headed set screw and flange nut the correct length would do nicely.
Plenty suppliers online but postage would cost more than the items.
Why not try your local Honda Power equipment dealer or motorcycle dealer first?
« Last Edit: March 12, 2025, 07:38:57 AM by Skoti »
Skoti
1976 Honda CB750F1
« Reply #2 on: March 12, 2025, 10:38:47 AM »
They are definitely the correct screws, Honda used slotted pan head screws in this location for easier(??) adjustment.
I don't know what the sizes are but I can say they are very fine pitch.
Are you sure they are beyond saving George? Personally I would take them off and take them to the plater not far from you, Ashford Chrome Plating who are actually located in Crayford, about a 15min walk from the train station. They can relate them for you. They should be yellow passivated. When you remove them make sure you measure the length of the thread protruding from the locking nut on each one and make sure you draw a diagram with a number of the carb where each adjuster fits as they operate the choke flaps and you need all the flaps to fully open when running. The best way to do it really is to take the carb bank off the engine so you can see what you are doing.
If Ashford platers are unable to save what you have I would be surprised.
Offline Athame57
« Reply #3 on: March 12, 2025, 10:42:44 AM »
Thanks for this Dave. The image btw is a screen grab of Ebay.
Offline Skoti
« Reply #4 on: March 12, 2025, 03:07:24 PM »
It looks like those screws and nuts are only supplied with a complete carb assembly.
On the CMSNL parts diagram linked below I think possibly the screw and nut you refer to are shown to the left of the carb slide, item 107?
https://images.cmsnl.com/img/partslists/honda-cb400f2-england-engine-group-1j-1k-2j-2k_bigma000081e01-4_3e89.gif
Anyhow, good luck.
« Last Edit: March 12, 2025, 03:22:15 PM by Skoti »
Skoti
1976 Honda CB750F1
« Reply #5 on: March 12, 2025, 03:17:18 PM »
Is a replacement  SS bolt & nut not available then?
Offline Athame57
« Reply #6 on: March 12, 2025, 04:33:29 PM »
This is what I think now. As a separate item I think what I want is an orphaned item.  :( I guess I'll just have to apply a lot of elbow grease at some point.  ::)
Offline Athame57
« Reply #7 on: March 12, 2025, 04:34:41 PM »
It seems one can't get these items on their own full stop.  :(
« Reply #8 on: March 12, 2025, 05:04:55 PM »
Could you not stick the bolt in a lathe and turn/face the head down slightly before replacing it? Same with the nut - file the faces down & replate? Or are they beyond that?
Offline Skoti
« Reply #9 on: March 12, 2025, 05:50:16 PM »
What's the size and length of the bolt?
If it's a fine thread as Dave suggests it's probably 0.50 pitch which is available in M4 or M5 or 0.75 if it's M6 size.
Easily found online and also available in stainless steel.
Hope you get sorted.
Skoti
1976 Honda CB750F1
Offline Mikep328
« Reply #10 on: March 12, 2025, 06:15:43 PM »
You are WAAAAY more dedicated than I am...I would just wire brush the screw/nut shoot it with some aluminum paint and call it done!!!
Mine:
1976 CB400F
1973 Norton 850 Commando
2015 BMW R9T
2017 BMW R1200RS
2021 Moto Guzzi V7 Special
Wife's:
2015 Ducati Diavel
2019 Honda Africa Twin
2019 Honda NCT750
Offline Seabeowner
« Reply #11 on: March 12, 2025, 06:41:08 PM »
4mm x 13mm cheese hd on the 500s. Probably the same.
https://www.ebay.co.uk/itm/321490372837
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline Skoti
« Reply #12 on: March 12, 2025, 06:52:14 PM »
Those ebay ones are the standard 0.70 thread pitch tho, which are very easily obtained.
It may be the fine pitch ones that are 0.50 required?
Skoti
1976 Honda CB750F1
Offline Athame57
« Reply #13 on: March 12, 2025, 07:04:39 PM »
Does it actually matter very much? :-\
Offline Skoti
« Reply #14 on: March 12, 2025, 07:34:03 PM »
It won't screw into the bracket if it's the wrong thread.
Better to remove the bolt and measure it with a thread gauge first and establish which thread it actually is.
Good luck
Skoti
1976 Honda CB750F1
