Author Topic: Advice on which replacement spark plug wire to buy  (Read 1364 times)
Offline kellanphil
« on: March 14, 2025, 02:42:48 AM »
Where do you guys get them and what do you recommend? I've got a 1980 CB750K with a Dyna 2000 ignition.
Re: Advice on which replacement spark plug wire to buy
« Reply #1 on: March 14, 2025, 09:14:17 AM »
IIRC my Dyna Coils leads were 7mm silicone leads with carbon core, lots on ebay in a choice of colours.
You will need the right crimp on connectors for the coil fittings if you make up your own leads, might work out easier to shorten a set at the plug cap end.
You have the option of going for copper core as well.
Updated
I bought my HT cable in the UK from the Green SparkPlug Co, they were 8mm not 7mm I checked my build log back in 2021.
You will find some in the US I would have thought.
https://www.gsparkplug.com/
« Last Edit: March 14, 2025, 10:37:07 AM by McCabe-Thiele (Ted) »
