Author Topic: First gear clunk  (Read 6741 times)
Offline Athame57
    • SeaWitch Artist
First gear clunk
« on: March 21, 2025, 03:53:09 PM »
Is a noisy first gear engagement the norm on a CB400F or something?  :o Even after I fitted a 'new' second hand clutch that was way better than the one I was replacing during an extensive rebuild it was soon back to that loud clunk when engaged, sometimes more quietly or louder than other times. could it be just me? Suggestions?
1978 CB400F2 named Elen.
Re: First gear clunk
« Reply #1 on: March 21, 2025, 04:26:14 PM »
I think that is most bikes due to nature of clutch
« Reply #2 on: March 21, 2025, 05:40:12 PM »
If when you roll the bike forward gently whilst popping it into gear does it still do it? If so there’s more adjustment in the clutch.
Also, maybe the chain just needs a  bit of slack taking out of it, that often allows a bit of lash at the gearbox end and a clonk when putting it in first.
One of my VFR’s does it but if you roll it gently, just a couple of inches or as I say just tighten the chain to what it should be it’s absolutely fine and snicks in beautifully.
Have a go at that and report back. First gear clonk is dead common as Bryan mentioned but you can dial a certain amount out with a bit of a methodical fiddle.
Offline Athame57
    • SeaWitch Artist
« Reply #3 on: March 21, 2025, 05:48:02 PM »
Thanks for the answers guys,  ;D  a bit of a storm in a tea cup then!  ;)
« Reply #4 on: March 21, 2025, 05:49:35 PM »
Pretty much but you can tell if there’s more adjustment by trying to see which works, dead simple and FREEEEEEE!
Winning
Offline TrickyMicky
« Reply #5 on: March 21, 2025, 11:09:53 PM »
Do you free the clutch off on the first start of the day?    Is your idling speed too high?  If it does it all the time, then yes to making sure the rear chain is not too slack, and also not too much slack in the clutch  cable. (Only adjust this with a cold engine!).  No synchromesh along with a multi-plate clutch means you will never get a completely silent 1st gear engagement.
Offline Mikep328
« Reply #6 on: March 22, 2025, 02:21:58 AM »
Different oils can produce more/less clunking. I haven't noticed my 400 to clunk any more then many other motorcycles I have owned.  I did have an experience last year where I changed oil and used full synthetic.  It was TERRIBLE for clunking and would seize the clutch if the bike wasn't run for a couple of days.  Put regular oil back in and the clunking was much reduced and the seizing disappeared.
Mine:
1976 CB400F
1973 Norton 850 Commando
2015 BMW R9T
2017 BMW R1200RS
2021 Moto Guzzi V7 Special
Wife's:
2015 Ducati Diavel
2019 Honda Africa Twin
2019 Honda NCT750
Offline Athame57
    • SeaWitch Artist
« Reply #7 on: March 22, 2025, 03:06:12 AM »
I use the highly recommended...
« Reply #8 on: March 22, 2025, 10:45:49 AM »
My VFR does that same thing Roo and is always a good indication the drive chain needs adjusting. The VFR does seem to be very gentle on drive chains unlike my old 250RSA that appeared to eat a drive chain for lunch!
« Reply #9 on: March 22, 2025, 10:49:43 AM »
What condition were the cush drive rubbers in George when you replaced the clutch? My 400 would clunk going into first from neutral and would sometimes clunk going into other gears as well. When I rebuilt the Flying Banana (aka Rat Bike) I checked the clutch cush drive on that and it was horrendous the amount of play on the clutch basket. I replaced the rubbers with a set I bought from Max and no clunk since👍
Offline Athame57
    • SeaWitch Artist
« Reply #10 on: March 22, 2025, 10:57:06 AM »
Hi Dave
During the rebuild the mechanic in charge showed me the amount of play in the clutch unit by causing noise rapidly twisting back and forth it in his hands. I got a new unit from 400Four spares and it did nothing of the sort, only a little bit of noise, so I can only imagine they were ok.
« Reply #11 on: March 22, 2025, 12:56:31 PM »
There should be no noise, if you can hear any or feel any play in the large gear on the back of the clutch it’s buggered I’m afraid. If you still have the old basket get some new rubbers from Max and do the mod, then swap out with existing clutch.
« Reply #12 on: March 22, 2025, 03:21:00 PM »
Ehyup Dave, yeah, they’re not bad on chains but that clunk is always a sure fire way to determine that the chain needs a tweak. Two mins on the centre stand for us though. I’ve done 6 CSK’s on the VTEC, in what’s now 187k miles on her. Gotta be good value, it’s not like she’s not being thrashed……..well not all the time!
« Reply #13 on: March 22, 2025, 03:33:37 PM »
We all know that anything over 20 mph and all of Bristol can hear your screaming Roo.
« Reply #14 on: March 22, 2025, 03:49:36 PM »
Morning Fester, screaming with 'glee' that is 8)
