Author Topic: charging issues  (Read 4350 times)
charging issues
« on: March 27, 2025, 05:30:02 PM »
hi all
  as the title suggests,the CB500 has charging issues,
at about  4,000rpm it produces a low charge,if I put the lights on,there is no increase,
I have checked the 3 yellow wires,all link to each other,
some time ago I fitted  a RR24 combined regulator/rectifier,
 could that have gone??
any ideas of what to test for?
thanks
Re: charging issues
« Reply #1 on: March 27, 2025, 05:32:54 PM »
Yes to first question but not necessarily.
There is a full charging system diagnostic system test in the Honda manual
Re: charging issues
« Reply #2 on: March 27, 2025, 06:57:45 PM »
OK
  I will check it out,
Re: charging issues
« Reply #3 on: March 28, 2025, 12:10:11 PM »
the rectifier/regulator  is an RR24,fitted about 10years ago,
  after playing with a multi meter ,the stator and rotor have continuity,
 on to Electex world web site,found a helpful page,on it is how to test the reg,
  my figures are not as specified,
ordered another ,my haven't prices  gone up!!!!
Re: charging issues
« Reply #4 on: March 28, 2025, 02:33:42 PM »
Make sure all your earth connections are clean and tight plus all the multiblock connectors or you may fry your new part
Re: charging issues
« Reply #5 on: March 30, 2025, 09:49:43 AM »
Ok,all terminals cleaned
I used a spray called Bulldog BDX,
a sort of deluxe version of WD40,and yes they did say it is suitable for electrical connections
Also an instruction on how to test the RR24 unit,
