Author Topic: One for the “Rubber Washer” gurus  (Read 8053 times)
« on: March 31, 2025, 11:14:30 AM »
I’m hoping one of you guys can help me source a load of replacement rubber washers for my son’s dining chairs.
They are 21mm OD, 15mm ID and 5mm thick. They act as shock absorbers between the trendy plastic bucket seat and the cantilevered legs.
I’m assuming they need to be soft as they squeeze up between two plates. This example is hard as rock and cracked.
I need 24 (6 on each chair).
Thanks in advance.
Steve
Offline kent400
Re: One for the “Rubber Washer” gurus
« Reply #1 on: March 31, 2025, 04:52:03 PM »
A thought on that, a computer mouse mat and a wad punch. The foam ones are 5 mm thick and although my largest wad punch is 19 mm one that size might do the job or maybe you can source a larger one.
« Reply #2 on: March 31, 2025, 05:05:28 PM »
Steve, ebay item 273087237790 does all sizes of hole punch, probably others but thats the first i found doing 15 and 20mm.
Then a sheet of what i know as insetion rubber which has reinforcing, hard wood block and hammer and you are away
« Reply #3 on: March 31, 2025, 05:09:11 PM »
Rubber sheet on fleabay
Offline Deano400
« Reply #4 on: March 31, 2025, 08:27:34 PM »
Would these be close enough, would have to use two on each.
https://www.rubberwashers.co.uk/M2_M36_Rubber_Washers/M14_Rubber_Washers/W0540
