Author Topic: Front brake pads  (Read 27011 times)
Offline Ken4004
Re: Front brake pads
« Reply #30 on: February 23, 2026, 05:30:18 PM »
Feel can often be about pad material, too hard and it feels wooden. Organic is normally the best for feel but suffers with dust and quick wear and of course brake fade if used very hard. Sintered are good but can be hard on the discs, still a dust problem though. I'm going to try some carbon pads next, got them on my 1300 and they are great, almost no dust, stop like hell and are kinder to the disc than sintered.
Have you bedded the pads in and removed the old bedding from the disc surface? Makes a hell of a difference if done correctly.
I always thought that brake pad material should match the brake disc material as Odd job stated sintered brake pads can be hard on discs.
On my modern bike ( Triumph 1050 ) the brakes are extremely good as you would expect from a modern bike but I have heard of people using non standard brake pads to give even better performance under heavy braking , unfortunately this has created excessive heat and caused the brakes discs to warp .
Now this is probably not the case on the older bikes because the braking force at the disc is not as great so heat produced is less than a modern machine but personally I would not fit non standard brake pads to my old Honda for fear of damaging the discs .
Please see this information from a brake manufacturer Ferodo :-
Brake pads must match the disc (rotor) material and type to ensure optimal performance, prevent premature wear, and avoid noise. Matching the friction material to the disc ensures proper "bedding-in" and effective heat management, as mismatched components can cause uneven rotor wear or brake failure.
Ferodo
Ferodo
 +2
Key Considerations for Matching Brake Pads and Discs:
Material Compatibility:
Steel Rotors: Standard, high-carbon steel discs are compatible with organic, semi-metallic, and ceramic pads.
Ceramic Pads: Ideal for daily driving, providing quiet, low-dust, and durable performance.
Semi-Metallic/Sintered Pads: Best for high-performance, heavy-duty, or racing applications, offering superior heat management, though they may be louder.
Carbon/Ceramic Discs: Require specialized pads; standard steel-compatible pads will not work.
Performance Matching: If you have high-performance, vented discs, you should use matching high-performance pads to handle increased heat, rather than base-level organic pads.
System Integrity: It is recommended to replace brake pads and discs as a matched system to avoid premature wear and brake pulsation.
Quality Standards: While brands can differ, ensure pads meet required safety standards (like ECE R90) for compatibility.
Ferodo
Ferodo
 +6
For most street vehicles, matching the manufacturer's original equipment (OE) material recommendation is the safest approach for balanced performance.
Would be interested in what the more experienced people in the group think , I have as I said not deviated from the standard pads for fear of causing damage to discs so my comments are not based on personal experience.
It would however be interesting to fit sintered pads  to my bike along with a compatible discs.
Offline Treve
« Reply #31 on: February 23, 2026, 05:59:20 PM »
Interesting "Ken4004"
But what are OE brake pads for our 50+ CB machines. Original it was asbestos brakes pads. I can't just accept that it says "OE" on something I buy in this case.
Even clean organic pads were sold as OE once upon a time. And those made no biker happy - or am I wrong.
Your "Key Consid....  statement feels much nicer to relate to. If all sellers also could explain what they actually are selling, most people would drive with the right type of brake pads fore there type of bikes.
« Reply #32 on: February 23, 2026, 06:16:04 PM »
These sohc bikes were produced right at the start of the first disc brakes fitted to production road bikes. As well as asbestos being removed from the brake pads, there have been huge improvements in the materials used as manufacturers tested and learnt how to improve braking performance.
I would say that modern pads of the right type for our discs are a big improvement over OE pads.
Offline Ken4004
« Reply #33 on: February 23, 2026, 07:22:56 PM »
I suppose selecting the appropriate alternative brake pad material that works bests with these older bikes would be best answered by a brake pad manufacturer like Ferodo who spend time researching the best materials for all applications.
Most developments are born from racing and the fruits of these improvements then spill over to main stream  bikes.
It would be interesting to see what brake pad materials are being used in classic bike races as I am sure they would like a pad that had half a chance of slowing the bike down.
I suppose the other consideration is that most race bikes will have a total rebuild after heavy duty racing so they are not really worried about getting 20,000 miles out of a set of pads and discs !
Maybe someone in this group has raced or knows some who has raced this age of bike .
spill over into
Offline Treve
« Reply #34 on: February 23, 2026, 08:40:01 PM »
Ferodo has only organic rear set to offer. Nothing for the front. According to my seek on there web sight. Sadly
