Author Topic: Ignition for dummies (like me)  (Read 10995 times)
Offline Rozabikes Tim
« on: April 29, 2025, 08:06:51 PM »
Just looking at this channel for more modern bikes but found this. About 400/4  but really good tutorial on how old school ignition works. I thought so anyway!
https://youtu.be/gCeDZMX4E9k?si=GYI-Z7zBPwnbM0ac
« Last Edit: April 29, 2025, 10:16:45 PM by Rozabikes Tim »
Re: Ignition for dummies (loke me)
« Reply #1 on: April 29, 2025, 08:50:04 PM »
OK except for using the big nut to rotate the crank
Re: Ignition for dummies (like me)
« Reply #2 on: April 30, 2025, 07:20:53 AM »
You can put the bike in gear, with the plugs out, easy enough to rotate the engine using the wheel.
As Bryan has said best to avoid using the end nut.
« Last Edit: April 30, 2025, 12:01:27 PM by McCabe-Thiele (Ted) »
« Reply #3 on: April 30, 2025, 09:40:18 AM »
Really just the explanation of how it all works that I felt was of interest. However why did they put a bloody great tempting nut in there if you are not suposed to use it!!??
« Reply #4 on: April 30, 2025, 01:02:45 PM »
IIRC Honda actually tell you to use the nut in the WM, I don't have a problem with using it myself so long as the plugs are out. Which means the bikes getting a service anyway and you're checking the ignition as well.
Offline Skoti
« Reply #5 on: May 01, 2025, 07:07:03 AM »
Have also used that nut to help gap the points, before fine tuning with a dwell meter and timing with a strobe light.
That's the way we were taught in the trade.
Skoti
1976 Honda CB750F1
