Author Topic: 400/4 OEM horn  (Read 3970 times)
Offline exvalvesetdabbler
400/4 OEM horn
« on: May 08, 2025, 07:04:02 PM »
Trying to find out what the original finish on the horn bracket  and  nut that holds the horn to the bracket was, zinc plate or black enamel ?  The big slotted screw with the fine thread has zinc plate on it but I'm not seeing traces elsewhere.
I currently have a zinc plate bath on the go and getting the urge to plate anything that's a bit crusty.
Best Regards
Dave.
Re: 400/4 OEM horn
« Reply #1 on: May 10, 2025, 07:26:17 AM »
I'll have a look at mine later and let you know.
Offline Toko_Jo
Re: 400/4 OEM horn
« Reply #2 on: May 10, 2025, 09:27:13 AM »
Black chassis paint.
Re: 400/4 OEM horn
« Reply #3 on: May 10, 2025, 09:51:26 PM »
Toko is correct.
Looking at my original bracket it is painted black the same as the frame (original ones also have a a part code painted in white on the bracket itself, code is 12V  H with the letters 3A105db below it and 1 6 Q below that).
The horn itself is BZP with the large mounting nut and fine thread screw being yellow passivated (as are the two wiring spade connectors on the horn).
Re: 400/4 OEM horn
« Reply #4 on: May 11, 2025, 06:58:14 AM »
(Confidently deciphers Honda’s cunning part code)
12 Volt Horn 3 Amp 105 Decibels.
Re: 400/4 OEM horn
« Reply #5 on: May 12, 2025, 10:47:18 AM »
Thanks.
I have some dreg ends in a satin black rattle can so that will have to do.
After a winter rest it never works anyway until you press the button and whack it with a screwdriver handle. I did fill it up with WD40 and suck it out again with a syringe but that only lasted 3-4 years.
Regards
Dave.
