Author Topic: MISFIRE ON NO4 CYLINDER  (Read 7045 times)
Offline blade918
« on: May 12, 2025, 04:34:28 PM »
HI ALL FINISHED REBUILDING MY CB500 K2 AT LAST 123 CYLINDERS PERFECT NO4 MISFIRING WHEN I TAKE PLUG OUT REALLY BLACK AND SOOTY [RICH]CARBS HAVE BEEN SONIC CLEANED DOUBLE CHECKED ALL JETS CLEAR IT HAS HAD ALL NEW COILS HT LEADS PLUGS POINT CONDENSERS BUT IM STRUGGLING TO UNDERSTAND WHY IT WILL NOT FIRE ON NO 4 ANY HELP APPRECIATED MANY THANKS KG
Re: MISFIRE ON NO4 CYLINDER
« Reply #1 on: May 12, 2025, 05:21:26 PM »
Please dont shout! If the plug is black its too rich.
What bits did you change in the carbs
Offline Athame57
    • SeaWitch Artist
« Reply #2 on: May 12, 2025, 05:59:05 PM »
Does it fire properly for a while after cleaning the plug, after all it managed to get sooted up. Also, are you sure the carb was reassembled properly. I ask that because my own bike managed to come out of a workshop with a needle jet tube missing, :o  lotsa smoke and misfiring. I finished the job myself.  ;)
1978 CB400F2 named Elen.
Offline Seabeowner
« Reply #3 on: May 12, 2025, 07:17:48 PM »
These bikes run rich at tickover. What do the other plugs look like? If it's the only one rich then usual suggestions: float height: fuel leaking past the O ring seal on the main jet: blocked passageways in carb
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #4 on: May 12, 2025, 10:14:02 PM »
Faulty plug?
Offline blade918
« Reply #5 on: May 13, 2025, 07:34:38 AM »
THANKS FOR INPUT NO BITS CHANGED IN CARB, CARBS WERE SONICALLY CLEANED , SWAPPED PLUGS STILL SAME , FLOAT HEIGHTS ALL SET TO MANUAL AND DOUBLE CHECKED, O RING LOOKS OK ,CARB ASSEMBLED OK STILL DOES NOT RUN PROPERLY AFTER CLEANING PLUG IM OPEN TO ANY OTHER IDEAS AS IM AT A LOSS WITH THIS ONE MANY THANKS FOR HELP SO FAR KG
« Reply #6 on: May 13, 2025, 07:55:14 AM »
Compression check to see what you've got  ?
« Reply #7 on: May 13, 2025, 08:11:39 AM »
Swap the leads over on cylinders 4 and 1, This will eliminate the coil if the misfire stays on cylinder 4. If it moves to one you can focus on cap, lead and coil in that order.
Compression check…make sure the tappet clearances are set correctly. Then check for compression relative to other cylinders.
You have already swapped the plugs eliminating a failing plug issue.
Failing that, it’s definitely a carb/fuel issue.
« Last Edit: May 13, 2025, 08:33:49 AM by Sesman »
Offline blade918
« Reply #8 on: May 13, 2025, 07:02:44 PM »
THANKS FOR INFO SWAPPED PLUGS AND COILS COMPRESSION OK IM LEANING TOWARDS CARB ISSUE ILL REMOVE TANK CARBS STRIP NO4 DOWN DOUBLE CHECK FLOATS ETC AT WEEK END THANKS ALL KG
« Reply #9 on: May 14, 2025, 10:44:29 AM »
If there's nothing fallen out in the carb (main jet, emulsion tube etc) then it's worthwhile with very close examination of idle circuit to be absolutely certain there's no impairment.
If the air passage into the carburettor for that circuit is blocked, then effectively it'll run full bleed on that idle jet as soon as you start it. Start will be OK as it's "choked" by this effect and won't be seen at initial running.
You could try turning the idle screw adjustment on that #4 to assess if it's doing anything. No response indicates it's blocked for air supply.
If so, you can remove the screw itself, spray carb cleaner down into there, then blow out with compressed air to see if it'll clear without dismantling.
« Reply #10 on: May 14, 2025, 04:33:31 PM »
This ^ is a simple test to verify the idle circuit is doing anything at all.
Turn the airscrew of carb #4 3 turns out and wait some 30 seconds and then fully in and wait another 30 seconds. If you notice within that minute some change in rpm - this does not have to be much! - the idle circuit still works, at least... to some degree (!). The change in rpm is often not much, but... when there's no change at all, it indicates the idle circuit of that carb is disfunctional and needs to be inspected. The good news is: you don't have to pull the rack as yours is a CB500 and with the rack in situ, the #4 is the most accessible of all four carbs. So, if you are any familiar with what's inside, you may just remove the floatbowl. All parts are accessible for inspection. You can unscrew the slow jet and spray carb cleaner in the orifice where it sat and hope the best of it. The main jet is easy to pull, so you can inspect its O-ring. BTW, you pull (and press in) the main jet! Do not twist the main jet! You may damage the tiny O-ring.
BTW, those who have no better filtering than pods for the air intake, run the risk of getting dust in the small orifice in the carb that is for air to the idle circuit (pilot system air jet in the pic below). Another good reason to abstain from pods IMO.
« Last Edit: May 15, 2025, 08:17:08 PM by deltarider »
Offline blade918
« Reply #11 on: June 01, 2025, 04:03:11 PM »
hi all sorry for delay holidays double checked compresion all ok all elecs ok so now going to remove carbs swap all inards from carb 4 to carb 1 and vice versa will let you know how this goes
Offline blade918
« Reply #12 on: June 02, 2025, 07:36:02 PM »
update removed carbs 1 2 3 inlets on head lovely and clean no4 black soput hand over inlet kicked her over and you can feel air being sucked in but also blowing back so im guessing inlet valve is a problem head off next to inspect
« Reply #13 on: June 03, 2025, 11:52:58 AM »
Are you sure the valve clearances are correct on that cylinder eg not too tight?
« Last Edit: June 04, 2025, 10:02:33 AM by Sesman »
« Reply #14 on: June 03, 2025, 01:07:31 PM »
I'm mildy puzzled that a compression test would give good reading but have significant loss back out through a closed valve.
Are you certain of the compression reading  ?  No difference at all from the others  ?
We had, on forum some time ago, something similar in that a recalcitrant cylinder was defying logic of all combined thinking chucked at it here, ultimately to be found in a "strangled" internal pipe within the header section of one exhaust pipe .... believe that was a 500 too.
Worthwhile adding that inspection to the pile along with valve clearance to check, as mentioned above.
