Author Topic: Rust removal from a painted tank ?  (Read 12125 times)
Offline Grewth
« on: June 15, 2025, 04:18:12 PM »
Here is my collection (so far) of 750F tanks.
CB750 in Flake Sunrise Orange with unfortunately a nasty dent in the top.
CB750F1 in rust all over, inside and out.
And CB750F2 in quite good condition except for a sodding great dent on the LH side.
All three are mucky on the inside,  fuel residue and maybe a failed liner on the F2, the F0 and F1 have loads of rust inside,  both fixed and loose flakes.
Fortunately none of them seem to have rotted out yet (I know where to look).
Ideally I'd like to use the Orange tank on my project bike, with it's 50 YO original paint.
I'm just wondering what the best way of dealing with the rust would be,  without damaging that paintwork any further  ? [ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ]
Offline Athame57
    • SeaWitch Artist
Re: Rust removal from a painted tank ?
« Reply #1 on: June 15, 2025, 05:25:25 PM »
If the dent in the orange tank is free of any creases I think it could easliy be pulled out.
https://youtu.be/dity9_i6UVY
« Last Edit: June 15, 2025, 05:31:04 PM by Athame57 »
1978 CB400F2 named Elen.
Offline Grewth
« Reply #2 on: June 15, 2025, 06:54:58 PM »
There's a nasty crease just by the hinge point of the filler flap, unfortunately.
I've no doubt that some of the dent may pull out with DIY  paintless dent removal tactics, but not that crease which annoyingly runs across the panel line.
A professional could probably get it near perfect, but it's unfortunately not worth it for an old, faded, chipped paintwork
« Reply #3 on: June 15, 2025, 07:36:49 PM »
Not sure if I saw this on this site or the yank site but they use a process called electrolosis iirc. It’s essentially a large cork or plastic bung that seals inside the opening with a large bent nail sticking through it, they then fill the tank with water ( there may be something in the water, not sure) and then attach a battery charger to the protruding end of the nail and the tank. Evidently the electrical charge forces rust off the inside of the tank and makes it attach to the nail or bolt. After a few hours, remove the nail and clean off the rust and keep repeating until all the rust is removed. From all reports it’s an excellent way or doing it and dirt cheap. Rinse the tank in diesel afterwards to prevent flash rust.
Sure someone one here who has done this can expound on any parts I’ve got wrong.
Offline Athame57
    • SeaWitch Artist
« Reply #4 on: June 15, 2025, 09:13:59 PM »
According to this youtube, and there are quite a few, you won't even need to that, unless perhaps if you are going to store it.  I gather that it does need to be done in a well ventilated place though, so not in your bedroom!  ;D
https://youtu.be/OGjtx2BgK-U?si=hwR--QUGHkMm-VXx
Offline Grewth
« Reply #5 on: June 15, 2025, 10:20:41 PM »
Thanks for that.
I'll have a good look tomorrow when I have some time to myself
« Reply #6 on: June 15, 2025, 10:44:21 PM »
DEOX-C, brilliant stuff. Pour it into the tank (it's powder), boil thf kettle and fill the tank to the brim. Wrap the tank up, leave it a couple of days (with some periodic shaking), undo the plug and be amazed at what comes out. I always dry mine with a hot air gun pushed into the filler cap. Once dry use diesel to stop it flash rusting.
You may have to do it a couple of times if the rust is bad.
DEOX-C is available direct from Bilt Hamber, about £18 with delivery.
« Reply #7 on: June 15, 2025, 11:50:22 PM »
Thanks for the links George. Watched a couple of vids of it being done, one used soda crystals and one used stuff used in outdoor swimming pools, being in the UK we don’t have a lot of outdoor swimming pools so soda crystals it is. £2 from Tesco’s btw.
I did think something was in the water so it’s nice to see that confirmed.
Everything seems fairly straightforward, seems simple. A spray can lid seems to be a good idea to suspend the anode in. Cut a slot to clear the cap hinge hole if required.
I like this method, you can just leave it to do it’s work and it gets too all the nooks and crannies, cheap as well. I’d say use hot water initially as it would dissolve the crystals better.
Got a nice tank with some light to medium interior rust, gonna give this a go myself soon.
Offline ozzybud
« Reply #8 on: June 16, 2025, 04:00:00 AM »
I have a method I use that gives  great results.
I start with filling the entire tank with Evapo-Rust. It is available in Europe. Let it soak for a week. It won't harm paint or eat away at metal. Shake and drain thru a filter and save it for use again. Get 1/2 gallon of diesel and a pound or so of lightweight chain.shake the tank at all angles to scour the walls. Drain into a large pan. You will notice debris and remaining evaporust which is water based pool at the bottom. Pour the diesel back into the tank less the debris and water. Repeat until  walls are clean and diesel is coming out clean. The coating of diesel will prevent flash rusting until you fill it up.
« Last Edit: June 16, 2025, 04:07:10 AM by ozzybud »
1976 Z50 PARAKEET YELLOW
1970 CT70 CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVERA BLUE
1973 CB350F FLAKE MATADOR RED
1974 CB350F GLORY BLUE BLACK
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
« Reply #9 on: June 16, 2025, 11:20:01 AM »
I used Evaporust on my 400 tank, in the UK it's become quite expensive, to fill the tank today would probably cost £60-70 on first filling.
« Reply #10 on: June 16, 2025, 01:03:11 PM »
I've bought Evaporust and TBH I didn't rate it much. Very expensive for what it is.
Offline DomP
« Reply #11 on: June 16, 2025, 01:27:18 PM »
I've done the electrolysis or 'reverse plating' as I like to call it, really easy way to clean a tank up.
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Offline Athame57
    • SeaWitch Artist
« Reply #12 on: June 16, 2025, 07:47:22 PM »
How toxic can electrolysis make a small area's air if it actually does? I have a tank to derust myself but I don't want to aphixiate me and my dog  :o  and I have no way of doing this anywhere else but my one room flat!  ::)
« Last Edit: June 16, 2025, 07:49:00 PM by Athame57 »
Offline DomP
« Reply #13 on: June 16, 2025, 08:26:15 PM »
I wouldn't like to say, I did it in my garage which is far from air tight
1975 XS650B
Offline SeanFD
    • Belfast-2-Belfast-By-Bike
« Reply #14 on: July 31, 2025, 11:22:51 AM »
If the rust is not too bad, and you're not in a hurry, you can fill it with vinegar, assisted by some nuts and bolts if needed. Big advantage is you can either keep the vinegar for reuse, or throw it down the sink.
I've used electrolysis also. You need an anode (-ve polarity, sacrificial part) that reaches towards the end of the tank; a short thing dangling through the filer cap won't be sufficient.
A horrible messy goo will come out of the filler cap, so protect the surface the tank is sitting on.
