Author Topic: Cb550f shock length  (Read 8784 times)
Offline DomP
Cb550f shock length
« on: June 21, 2025, 05:23:56 PM »
Can anyone tell me for certain the standard shock length on a cb550f,  mine seem to be standard and 335 centre to centre with the wheels on the ground.
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Re: Cb550f shock length
« Reply #1 on: June 22, 2025, 03:10:02 PM »
Mine measures 325mm on the centre stand.
Offline DomP
« Reply #2 on: June 22, 2025, 04:00:23 PM »
Maybe mine aren't standard length then, would 325mm and forks through the yoke 25mm give me 'quirky' handling?
1975 XS650B
« Reply #3 on: June 22, 2025, 09:54:59 PM »
Probably if mixed with certain tyres and pressures
« Reply #4 on: June 23, 2025, 03:27:48 AM »
I’m absolutely no expert on steering geometry, but I always favour the ‘standard’ set up as intended by the manufacturer. I can see that raising the rear and dropping the front might sharpen things up a bit, but whether this is detectable in practice, practically beneficial or wise, I’ll leave to others to comment.
« Last Edit: June 23, 2025, 05:17:11 PM by Sesman »
Online McCabe-Thiele (Ted)
« Reply #5 on: June 23, 2025, 04:46:58 AM »
As has been said by Phil I too have no understaing of the complexity of bike suspension design, that does not impede me from having an opinion based on "Teds Iffy Logic".
So here it is, were talking here about a difference of 10 mm in total length that does not sound like a big deal taking into account the varying weight of any individual rider when sat on his machine has a different nul point be they 9 stone or 17 stone spring rate will be most relevant here .
I suspect the big issue is where is this 10 mm difference in length, is it in the damper section (piston travel) body allowing the damper piston to travel further down, or is it in the length of the part between the bottom spring seat and the lower mounting or a bit of both. Chain slack might be only a small  factor. Lastly is there a difference in fully compressed length?
As has  been said going for standard is best, however when they are expensive or hard to obtain then I would not be overly cocerned. I suspect aftermarket damper manufacturers will use a stock damper section length (piston travel) then make the bottom section longer to suit a variety of applications.
As we are mostly riding these old bikes sensibly not on a race track I think it's unlikely to cause us handling problems bearing in mind other factors such as tyre choice, tyre pressures, unsprung weight from different wheel rim choices.
If the dampers are not leaking, passable cosmetically I would not worry about the 10 mm.
Offline DomP
« Reply #6 on: June 23, 2025, 04:09:53 PM »
I'd like to keep the rear fairly close to standard but was going on the fact it has 335mm fitted where as most replacements state 320mm.
Thanks for the replies guys, good to have some opinions to mull over.
1975 XS650B
« Reply #7 on: June 23, 2025, 05:18:13 PM »
I was really referring to dropped yokes…🤔
« Reply #8 on: June 23, 2025, 07:10:35 PM »
I assume you meant rear shock absorbers are you reffering to the front forks?
Offline Gromitdog
« Reply #9 on: June 23, 2025, 09:09:55 PM »
Hi Dom P
From what I been told for a CB550 k3 the rear shocks should be 321mm eye to eye. The link is for K3 below but they do the part shrouded version ones too.
https://www.wemoto.com/bike/honda/cb/550/1978/17132/rear-oe-replica-shocks?srsltid=AfmBOormkEjfHZaOp4q8YC7Hsnmka3yGq7N9xvNHDM_fPSaXcXtWE4VH
But not sure which you should have for a F1/F2 possibly  the upper shrouded ones ?
I found this in my pages of useful info I think Ken might have sent it over to me a few years back
https://www.bskspeedworks.co.uk/downloads/SHOCK%20FITTING%20APPLICATIONS.pdf
Hope this helps you with your question and project build I have just replaced Muttley's 🐕 rear shocks as in the process of doing a frame rebuild and I had the partly shrouded ones on which is not the correct ones for a K3 version I believe & I think there 325mm centre to centre ones (Possibly for a Honda CB750) .
Best Regards
Nigel
KEEPING IT SHINY SIDE UP IS ALWAYS A GOOD RESULT ON A RIDE OUT
Offline DomP
« Reply #10 on: June 23, 2025, 09:44:05 PM »
To clarify I was meaning rear shocks, mine are spraying oil out of the tops and I get a bobbing sensation
1975 XS650B
Offline Gromitdog
« Reply #11 on: June 24, 2025, 06:43:24 AM »
Hi Dom P
I can check what length rear shocks came off Mutely they are top shrouded ones if that would help you but I have a feeling they are 335mm, You couldn't seem to get 321mm lengths for ages now they seem to be in stock everywhere.
« Reply #12 on: June 24, 2025, 07:45:28 PM »
I was referring to the 25mm….
Offline DomP
« Reply #13 on: June 24, 2025, 10:52:15 PM »
Ah yes, I just re-read it
1975 XS650B
Offline Gromitdog
« Reply #14 on: June 25, 2025, 10:27:30 AM »
Hi Dom P
I have measured my rear shocks and they look as if they are 321mm upper shrouded ones which I believe is not correct for a K3  (picture below)
I am replacing these if you are looking for a pair email me with a offer if your interested
sorry the pictures are not that good with tape measure placement
Nigel
