Author Topic: Snapped bolt, now what?  (Read 1308 times)
Offline exvalvesetdabbler
Re: Snapped bolt, now what?
« Reply #15 on: July 02, 2025, 02:37:35 PM »
If the hole ends up bigger than 6.3, might be worth a look at Time-sert thread repair and the tapping size might be larger than helicoil. These are a more permanent repair compared to helicoil which sometimes come out with the bolt.
Regards
Dave.
« Reply #16 on: July 02, 2025, 04:51:00 PM »
Way cheaper than timeserts and standard outer thread
Offline neat street
« Reply #17 on: July 03, 2025, 07:54:26 AM »
you coulc place a nut on the opersite side toi the bolt head and try to weld it through the hole to the remaining stud. this will provide heat to loosten and should then be able to be undone. I have done this and got away with it a few times
CB500 1975
CB750F 1976
KLX250 1983
Lambretta SX200 1979
Mini Mayfair 1984
Offline TrickyMicky
« Reply #18 on: July 03, 2025, 08:34:50 AM »
Just a random thought, eons ago I went to ride away on my 750, forgetting to remove the padlock and chain which was through the front wheel. The result being the front stay was bent to buggery.  Being a tightwad, I just removed it, found the OE mudguard to still be rigid enough, and just fitted a couple of small rubber bungs in the fixing holes. I suppose you're going to say it's for the lower stay?  Attached pic (Hopefully) shows bike without front stay. Please excuse the red abominations fitted, but they came at the "right" price, and at a time of severe immaturity.
« Last Edit: July 03, 2025, 08:39:20 AM by TrickyMicky »
Offline Mikep328
« Reply #19 on: July 03, 2025, 09:33:06 AM »
Why not drill out the bolt/install a Helicoil?  I suspect that's what a shop would do if they couldn't remove the bolt's remains.  Regardless of method, the bolt would probably have to have a hole drilled in it anyway.  It MIGHT be removable with an Easy-Out which would preserve the existing threads but that also requires drilling a hole in the bolt.
I'm not a huge fan of Easy Outs because if you use one and IT breaks, you how have a hardened steel stub in the middle of the bolt - EXTREMELY difficult to drill out!  No need to ask how I know that!  :)
Offline Athame57
    • SeaWitch Artist
« Reply #20 on: July 04, 2025, 03:04:08 PM »
It's out!  ;D I left my bike with the Brazilian guy at Get Fixed Motorcycles and came back at noon, an hour and a bit away. I don't know how he did it and I didn't ask, pigeon english is a struggle too, maybe he was a dentist in a past life?  ;) Only cost £15.00 and I got a free nut and bolt too!  ;D
Thanks for all the input guy's , there's been some learning done from this. :)
1978 CB400F2 called Elen.
« Reply #21 on: July 04, 2025, 03:30:21 PM »
Good news.
Looks like one of the fillings that I spat out a while ago.
A generous smear of grease or anti seize before the bolt goes back in. Chain lube or wipe your dip stick on it is better than nothing to ward of corrosion.
Regards
Dave
Offline Mikep328
« Reply #22 on: July 04, 2025, 04:48:36 PM »
£15?  That's great, beats the heck out of doing it yourself!!!!  :)
Offline Craizeehair
« Reply #23 on: July 04, 2025, 05:18:50 PM »
That’s a result
« Reply #24 on: July 05, 2025, 07:07:33 PM »
Great result,.🙂
Offline Athame57
    • SeaWitch Artist
« Reply #25 on: July 05, 2025, 07:31:38 PM »
Great result,.🙂
Actually a bit of a relief too. I was getting ready for a scenario where it would be cheaper to get a new fork leg fitted, admittedly a chance to change the fork seals at the same time. A good fork leg would have cost me £39.00 to get from 400four bits. Not a bad price but rather the need wasn't there.  ;)
