Author Topic: cylinder head oil seals  (Read 9170 times)
Offline bigmockuk
« on: July 09, 2025, 05:33:38 PM »
i have the cb550 k3 and found during the initial rebuild of the engine that the head had to be removed for one reason or another
 so i ended up doing away with the pesky oil seals at each end of the head between that n the barrel.
i fitted a 7mm dowel to each side and the head fits snuggly onto the dowels n torqued down.
have done 150 miles so far and all is good,no leaks and cyclinders/plugs are dry,means you dont have to buy a full gasket set
any time the head comes off too.my next step is to cut off the studs that hold the inlet stubs on,drill and tap threads so that
the stubs can be fitted to the carbs before mounting them and 10mm bolts to hold them on instead of the painstaking task
of trying to feed a bank of carbs past the stubs and squashing the inlet rubbers,what a job that is!
Offline bigmockuk
Re: cylinder head oil seals
« Reply #1 on: July 09, 2025, 05:36:42 PM »
i put a small optional oring roud the dowel as theres a small ridge there from around the hole that was drilled,not that it would be needed,was just to round it off lol
« Reply #2 on: July 09, 2025, 06:54:32 PM »
Why cut off the studs as they are threaded into the head
Offline bigmockuk
« Reply #3 on: July 09, 2025, 07:27:43 PM »
tried unscrewing them but they wont budge,thought they might snap off
« Reply #4 on: July 09, 2025, 08:46:45 PM »
Heat the head and stud, if they snap its no different to cutting them off is it
