Author Topic: Spring caliper  (Read 8576 times)
Spring caliper
« on: July 10, 2025, 08:35:13 AM »
Does this spring ever need replacement? I can adjust the caliper on my CB500 as much as I want, so it has the 0.15mm gap between the disk and pad B recommended in the manual. Only... that gap will soon decrease. Am I the only one? Could renewal of forsaid spring bring some positive effect? Or would removal of that spring and its bolt altogether, as was suggested in the international forum, have more effect?
Re: Spring caliper
« Reply #1 on: July 10, 2025, 08:53:50 AM »
I have removed the spring, so the caliper can move freely
Those springs have been discarded for the last 50years
It should give a more positive brake
Offline florence
Re: Spring caliper
« Reply #2 on: July 10, 2025, 09:18:23 AM »
Thank you, I did not know this.
Does it make much difference removing the spring?  Have lots done this?  I've been riding with this particular spring for 30 years on this bike.  Does the calliper rattle without it?  Does the adjustment procedure change, i.e. turn adjuster until resistance is felt, back off until wheel is free, then back off a further 1/8th turn?
I am intrigued.
Addendum: I see feeler gauges are mentioned elsewhere so now doubly confused, never used them for the fixed pad before.  Tried to download the 500 manual from Aladdin's cave but link doesn't work for me.
« Last Edit: July 10, 2025, 09:41:57 AM by florence »
Re: Spring caliper
« Reply #3 on: July 10, 2025, 09:45:33 AM »
Just adjust the clearance in the normal way,
The caliper shouldn't rattle,
It should help the pads to bed in and align easily
Re: Spring caliper
« Reply #4 on: July 10, 2025, 10:17:02 AM »
I am intrigued.
Yes.
It's, effectively, the role of retraction acted by the seal on hydraulic design of all brake calipers, that this is substitute for.
The pads MUST be withdrawn from pressure contact (facilitated by that seal retraction) that makes the system work. They are designed differently with various seal retraction geometry for different caliper designs .... 2 pot, 4 pot, sliding one sided operation .... to make them work as designed via precise retraction dimension.
The spring does this,, in combination with the piston seal to give correct operation.
The largest error in nearly all caliper is when the seal groove, geometry, retraction etc are compromised through build up of dirt etc to restrict retraction movement. This ultimately makes the pads drag continually above design target and leads to "casual" glazing, which wouldn't happen if that operation was entirely fulfilled.
Attention to the seal, groove and assembly pays dividend in brake operation.  There's absolutely no weather sealing on these calipers, maintenance is paramount in keeping them as designed.
The most effective assembly lubricant for the seal is silicone grease as it's most resistant to water ingress, change of consistency in use and can virtually eliminate galvanic corrosion which is prime cause of decay in them.
Offline florence
Re: Spring caliper
« Reply #5 on: July 10, 2025, 10:21:26 AM »
Yes.
[/quote]
thank you.  Are you saying the spring is necessary and should not be removed?
Re: Spring caliper
« Reply #6 on: July 10, 2025, 10:50:19 AM »
Yes, correct.
The seal on this calliper must move in retraction enough for TWO piston to give correct (non braking) clearance. In doing that, the spring "distributes" that clearance equally across the two pads in relation to the disc face .... IF set correctly.
Too tight an adjustment (set point of screw) and it'll not "take" the correct clearance over to that side as it should. Too loose a setting of screw position and it'll take all of the available clearance over to the fixed pad side, leaving the hydraulic side dragging.
Used harder, extensively, and you'd be adjusting the screw daily in effect. This taking the place of a naturally occurring fully hydraulic system design.
Its a hybrid design with compromised operation. Effective, but needing careful attention to function at it's peak.
Offline florence
Re: Spring caliper
« Reply #7 on: July 10, 2025, 11:10:41 AM »
That's excellent advice K2-K6, many thanks.  I will leave mine as is in that case, it is working very well, especially since fitting new master cylinder.
Incidentally, taking your point about exposure to the elements, I have fitted a stainless steel piston as previously was subject to annual rebuild of the calliper, mainly due to all year round riding.  This has markedly improved durability and am now on year 3 without calliper rebuild.
On a separate note, the squeaking problem, I have never been able to solve, even after chamfering pads etc.  Strangely, I have found when the brake is well adjusted and working well, it squeaks loudly.  After a time the squeaking diminishes and so does the braking force.  This indicates time for an adjustment, which I carry out, and the squeak returns.  I am used to this routine and put up with it as a quirk of the machine.
Re: Spring caliper
« Reply #8 on: July 10, 2025, 07:51:28 PM »
[...] The seal on this calliper must move in retraction enough for TWO piston to give correct [...]
I'm afraid I don't understand what you mean by 'TWO piston'.
Let me get this clear: is the design thus that ideally that gap between the disk and pad B remains 0.15mm? Or... 0,075mm on either side of the disk?
I don't know about applying silicone grease on the rubber seal. Opinions differ on this.
On the outside after fitting the seal and piston, yes, silicone grease is fine, but in the groove and on the seal itself, prior to assembly... hmm, I have my doubts. I have done it the last time I renewed the seal and I have the feeling it affects its retraction performance in a negative way (less twisting of the rubber). But to be honest... I am not sure. Next time I will only apply some brake fluid just enough to get seal and piston in and then seal the outside with a silicone grease like ATE.
Addition: free length of that spring on mine is 32,5mm.
« Last Edit: July 10, 2025, 08:04:52 PM by deltarider »
Re: Spring caliper
« Reply #9 on: July 10, 2025, 08:08:47 PM »
None of these bikes have 2 piston calipers
But for info, twin piston can have a piston either side of the disc ,in this case the caliper is normally fixed, like the early Lockheed caliper in the 70's
But sometimes a caliper has both pistons on the same side, and the caliper moves, slides or swivels
Offline DomP
Re: Spring caliper
« Reply #10 on: July 10, 2025, 08:10:05 PM »
I always use red rubber grease on brake rubber components
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Re: Spring caliper
« Reply #11 on: July 11, 2025, 06:50:19 AM »
By two piston, I'm referring to having two X seal retraction, one for each pad of that "conventional type of caliper.
This Honda type, hybrid of mechanical and hydraulic design, still needs two X pad clearance when brake is released to work well. With only one piston seal, that has to facilitate the total clearance needed when it's retracting, then to be "distributed" by the spring and clearance you've set on that static pad. Without which one or both pads will be too heavily in contact with the disc rotor.
Adjusting the screw, you are effectively chasing pad wear as it accumulated for that static pad as its not facilitated by the hydraulic design.
Re: Spring caliper
« Reply #12 on: July 11, 2025, 08:13:05 AM »
Thanks for explaining. Here's the reason I brought it up. I have a very slight unrest in steering, between say 60 and 85km/h. I have checked everything and all is good. I have noticed that whenever I have (re)adjusted that bolt to spec, the unrest is gone.
It is not dangerous; with just one hand at the handlebar that slight unrest does not increase, let alone it develops into a tankslapper. Also there is no increase in the disk's temperature. It's a minor issue. I'll do some experimenting and will report back if removal of bolt and spring brings any improvement.
Re: Spring caliper
« Reply #13 on: July 11, 2025, 10:38:44 AM »
Forgive me for asking the obvious, have you removed the long caliper arm and checked the pivot pin for wear, iirc there are two O rings fitted to keep water out. Also is the bracket for the top fixed part secured correctly, are the threads in good condition where it bolts to the forks bottoms?
Re: Spring caliper
« Reply #14 on: July 11, 2025, 11:52:12 AM »
My pivot pin still swings like new. I have understood there can be a problem with previous models. If you consult the appropiate parts list for my CB500K2, you will see my model has the newer -390- caliper holder. Also the pin underwent modification. Maybe that's the reason I never had to service these parts. As a matter of fact, the two O-rings I have bought decades ago, are still in their plastic bag.
