Author Topic: She's Finished  (Read 14429 times)
Offline DomP
Re: She's Finished
« Reply #15 on: July 15, 2025, 06:51:40 PM »
Looks great, Did you flip the forks and caliper or was that already done?  I've done the same on my 550 but had a few people say as its no longer trailing it will cause issues, it doesn't seem to to me.
Did you have to play with jets to get the pods to work?
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Offline Nashfly
Re: She's Finished
« Reply #16 on: July 15, 2025, 09:06:56 PM »
The project came with a front master cylinder and caliper from a mini-moto! Just one of the many bodges.....
Swapped the fork legs so the caliper sits behind the forks, had the disc drilled, fitted a braided hose and modern pads. With the reduction in the bike's weight the braking feels ok, but I  have an AP lockheed set up I could fit, if I think it needs improving
There seems no issues with the caliper behind the fork (I use a digital speedo, so the speedo drive is not an issue). I did the same on my TZ Yamaha and it's been working great for a many miles
For carburation I upped the pilots by 1 and the mains by 3 and it pulls really smoothly throughout the rev range. There is a slight popping on the overun,  so a little bit of tweaking is needed
« Last Edit: July 15, 2025, 09:59:46 PM by Nashfly »
Offline neat street
Re: She's Finished
« Reply #17 on: July 16, 2025, 07:43:40 AM »
thaats a super looking bike, well done and hats of to you :-)
CB500 1975
CB750F 1976
KLX250 1983
Lambretta SX200 1979
Mini Mayfair 1984
Offline Murf
Re: She's Finished
« Reply #18 on: July 23, 2025, 11:47:36 PM »
Fantastic build looks great well done and so good that it is road going, should draw a quite a bit of attention.
