Author Topic: Front Fork Cap F Mark  (Read 3514 times)
Offline JEZZAIRONBRIDGE
« on: July 15, 2025, 08:52:10 PM »
New to forum.
Recent purchase of 400/4.
Forks need investigation as leaking Oil from bottom.
Last owner replaced Stanchions.
Does the "F" marking to the Front Lower Fork Caps have any significance at all?
Re: Front Fork Cap F Mark
« Reply #1 on: July 15, 2025, 08:55:46 PM »
F means front so make sure you have them on the correct way round and follow the manual when doing the bolts up and torque to the correct setting👍.
Similar to tgd handlebar clamps if you take them off for any reason, the have a dot that faces the back. When you do these up you tighten the front bolts first.
« Reply #2 on: July 15, 2025, 09:01:51 PM »
There is a bulletin about this in ashs dropbox
« Reply #3 on: July 15, 2025, 09:07:37 PM »
Many thanks for advice.
Much appreciated.
Believe Fork Oil loss due to the re use of Copper Washers.
Ordered replacements now.
Thanks again.
