Author Topic: NGK XD05FR wanted  (Read 6357 times)
Offline OZZYSBIKES
NGK XD05FR wanted
« on: July 20, 2025, 02:42:15 PM »
Hi,
Has anyone got or know a supplier that has the above NGK XD05FR plug caps, I've fitted new plugs that have built in resistance so I want the plug caps that have removable resistors, I've got three typically so want preferably two caps so that I have one spare, I remove the resistors and make a brass insert up so that I only have 5K resistance
Offline Bloggs
Re: NGK XD05FR wanted
« Reply #1 on: July 20, 2025, 05:14:49 PM »
Hi,  A quick search found this potential supplier. Claims stock!
https://www.motorcycleproducts.co.uk/ngk-xd05f-black-spark-plug-cap/1/005231
Offline OZZYSBIKES
« Reply #2 on: July 20, 2025, 05:20:58 PM »
Hi
Thanks but it's the red ones I want, spurious black ones are common but I want to keep the original red ones (I am a bit anal about some stuff !), I might end up having to fit four black ones, also I don't want alternative spark plugs as I like the Denso iridium plugs with built-in 5K resistance
Offline OZZYSBIKES
« Reply #3 on: July 20, 2025, 05:27:07 PM »
I have found a company called motorcycle parts store that are showing stock online so I've emailed them to confirm that they have physical stock
Offline OZZYSBIKES
« Reply #4 on: July 21, 2025, 11:45:43 AM »
Well it shows that you should support your local shops, I went to Sprint motorcycle spares in Wakefield this morning and got the correct part XD05FR off the shelf, two for £9 a bargain
So all sorted now 👍
