Fork Top Nuts
Topic: Fork Top Nuts (Read 12453 times)
Fork Top Nuts
November 29, 2010, 10:30:19 AM »
My CB650 runs 35mm forks that slot into a set of Cb550 yokes. They have various air assist elements on them (pipes, valves etc) that look messy, foul my handlebars & that I don't really want.
Anyway, I thought that rather than try to blank off the various holes it might be simpler and easier to replace the nuts at the top of the stanchions with some "standard" ones.
My questions is, does anyone know if these fittings / threads for these nuts are the same size for my bike as for the 550? If so, can I just pick up a set of nuts from the more common 550 stanchions and use those?
...and here's a piccie of the RHS fork top so you can see the nut/fittings I want to eliminate. The air valve sticks up and fouls the handlebars when it's in the right position and there should also be a pipe (similar to an old style bicycle pump end fitting) that runs from the hole under the valve to the other fork top.
Thanks in advance!
Andy
Re: Fork Top Nuts
November 29, 2010, 02:17:01 PM »
Can't be certain as Honda bought in a lot of forks but if they are the same diameter chances are the threads are the same, if bigger probably not
Yoshi823
Biker to the bone...
Re: Fork Top Nuts
November 30, 2010, 01:21:46 PM »
Those air fork caps are very similar to the CBX550F2 ones that I had fitted to the CBX1000ZA forks on my 750/823F2. The Schraeder valve is as per the air valve on the tyres, so not old at all. If you want clean, the fork tops from a CBX1000ZA would fit perfectly, with a small black cap that screws into the fork top. I might have some in my box of bits in the shed. I'll have a look when I can fight my way past the snow to get to the shed...
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
Re: Fork Top Nuts
November 30, 2010, 06:32:20 PM »
Be great to know what thread & diameter they are. ..... possibly a piccie if you can battle through the snow?! Thanks.
lordwhimsey
Newbie
Re: Fork Top Nuts
December 02, 2010, 08:43:50 AM »
CB550 fork top nuts are a 28mm x 1.5mm thread
Should poke up about 12mm above the top of your forks and stick 24mm into them, 36 mm overall length.
Hope this helps.
Last Edit: December 02, 2010, 08:49:02 AM by lordwhimsey
Re: Fork Top Nuts
December 02, 2010, 08:22:46 PM »
Thank-you! I'll check the dimensions over the weekend.
Re: Fork Top Nuts
December 04, 2010, 09:46:02 AM »
Photo of the CB650 version. These are the same thread - 1.5mm but the diameter is different at 31mm, as shown in the piccie.
Seems odd that they are the same diameter forks but quite different diameter nuts?
I may just revert to Plan A which is to find the right sized bolts & copper washers to replace the air valves. For this I need anthree M8 x 1.0 (see piccie - is that metric fine?) which will replace the brass valve in the piccie, & also use them to fill the two holes where the air balance pipes enter the fork tops, so if anyone has any spares of this size...please let me know.
All my M8 bolts seem to be x1.25 and local hardware shops aren't what they used to be.
SteveD CB500K0
Administrator
Ride on the Steel Breeze...
Re: Fork Top Nuts
December 04, 2010, 11:21:12 AM »
Thinner tubes = less weight?
K2-K6
Re: Fork Top Nuts
December 05, 2010, 07:44:19 PM »
You may have a problem finding any off the shelf fine pitch metric stuff.
As stop gap you could cut the protruding part above the the brass hex off the existing and make some brass plugs up to fit the bore then solder them in to in effect "make" a bolt.
BigAl (Alan)
Hope its sunny at the weekend
Re: Fork Top Nuts
December 05, 2010, 09:33:00 PM »
The CB750 K0-K6 are 28mm, I replaced 2 last year on my K4. Hope the information helps
Alan
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
www.alans-electrics.co.uk
Yoshi823
Re: Fork Top Nuts
Reply #10 on:
December 08, 2010, 09:18:43 PM »
These are the ones from my CBX1000ZA fork legs that I used CBX550F2 air fork caps in. They have the same size threads as the ones shown in the photos & come with the black plated cap plates. I don't think that I have the 'O' rings but if you want them for
Yamaha R1 2001
Honda XR400R 1997
Honda CB125T2 1980
Re: Fork Top Nuts
Reply #11 on:
December 10, 2010, 08:57:29 PM »
....I've been meaning to mention that my wife bought me the mother of all tap-and-die kits for my birthday. Quality not quantity, I always say but the ladies seem to thing bigger is better...so this kit has everything. I'll post a piccie soon, the point being, I've now started cutting my own bolts (m8x1.0), using some long M8 bolts where the top of the shank is smooth.
First one worked a treat - beginners luck - and now it and a copper washer are in place in the fork top. The second one the thread was cut at a crazy angle...but I'll keep at it as it's a good skill to have. Pics to follow.
Yoshi - your fork tops diameter? See my picture for the dimensions on my current ones - your gauge shows c.28mm (?) ..I need 30.78 (is that 30 or 31?). Anyway, can you let me know what yours are. I'll probably go with my home-cut bolts for now but be nice to have some tidier fork-tops in reserve too - thanks!
K2-K6
Re: Fork Top Nuts
Reply #12 on:
December 10, 2010, 09:39:09 PM »
Sounds like a good present Andy, have you got any pro-lubrication for it? I've always used some called "rocol" I think, and it makes for really smooth cuts.
Yoshi823
Re: Fork Top Nuts
Reply #13 on:
December 11, 2010, 11:29:38 AM »
My vernier measurement is the same as yours...the figure is where it's adjacent to the '0' mark, which is just below the 31mm...don't know how you read 28mm though.
PM sent just before I read this post.
Yamaha R1 2001
Honda XR400R 1997
Honda CB125T2 1980
Re: Fork Top Nuts
Reply #14 on:
January 31, 2011, 06:54:03 PM »
Cheers Yoshi - I've swapped in the ones you sent & they fit perfectly; and now so do my handlebars.
Fork Top Nuts
