Author Topic: CLUTCH SWITCH ???  (Read 10005 times)
Offline Mikep328
CLUTCH SWITCH ???
« on: August 03, 2025, 02:59:37 PM »
I have seen references to a "clutch switch" that locks out the starter unless the gear shifter is in neutral OR the clutch level is pulled in.  My '76 UK CB400 will engage the starter in gear with the clutch released.
 The owners manual for the bike does not mention a clutch switch BUT the electrical schematic in the same owners manual shows a clutch switch in the UK model.
Did a UK bike have a clutch switch or not???
Mine:
1976 CB400F
1973 Norton 850 Commando
2015 BMW R9T
2017 BMW R1200RS
2021 Moto Guzzi V7 Special
Wife's:
2015 Ducati Diavel
2019 Honda Africa Twin
2019 Honda NCT750
Re: CLUTCH SWITCH ???
« Reply #1 on: August 03, 2025, 03:40:48 PM »
My  S plate UK 400 had a clutch switch.
« Last Edit: August 03, 2025, 03:43:01 PM by McCabe-Thiele (Ted) »
Offline TrickyMicky
« Reply #2 on: August 03, 2025, 04:17:00 PM »
Nice and easy to fit, Silvers has the genuine article in stock, about £21 ish.  You really appreciate it when you stall the bike at the head of a line of traffic.
Offline Mikep328
« Reply #3 on: August 03, 2025, 05:01:06 PM »
Interesting!  I looked at the DSS listing; my '76 400 definitely does not have that switch so I assume in its past life the switch was removed.  Thanks!!
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
Offline exvalvesetdabbler
« Reply #4 on: August 03, 2025, 06:20:21 PM »
You will need the diode as well that's mounted near the voltage regulator.
Regards
Dave
Offline Athame57
« Reply #5 on: August 03, 2025, 06:44:46 PM »
When I first got my CB400F2 seven years ago I didn't know the starter clutch existed and it took a few years for me to find out. I thought it was simply like my Suzuki RG500 Gammas were, that  they start in neutral only. However I explored the reason for that hole the electric cable plugs into and learned all about it on this forum.  ;D
I got a cable from DSS and had it fitted for me.  ;)
1978 CB400F2 named Elen.
Offline Athame57
« Reply #6 on: August 03, 2025, 06:49:23 PM »
By the way, messed up my first cable trying to fit it myself by jamming it in the said hole.  ::) You should take the clutch lever off and thread it in from the inside.
« Last Edit: August 03, 2025, 11:23:03 PM by Athame57 »
« Reply #7 on: August 03, 2025, 06:50:32 PM »
The clutch switch is same as front brake light switch on drum braked 125, it fits into a hole in the mounting after you remove the lever blade pushing in from lever side
Offline Mikep328
« Reply #8 on: August 04, 2025, 07:22:02 AM »
Haven't decided whether to buy/install the switch.  TBH, I can't see that I need it.  It prevents accidentally engaging the starter/bike lurching forward while in gear/clutch engaged but I have never had a problem with that.  It's automatic for me to pull in the clutch/hit start if I stall the bike since I learned on bikes before clutch or kickstand interlocks existed.
OTOH, I like things to work as they were designed to work so that part of me wants the switch in place/functioning correctly.  Not sure which of my multiple personalities will gain the upper hand... ;)
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
Offline TrickyMicky
« Reply #9 on: August 04, 2025, 08:30:47 AM »
If your bike is wired correctly, the starter will not work unless the neutral light is on. so disengaging the clutch will have no effect without the switch.  A possible real situation being, sitting in traffic, engage 1st gear, change feet so rear brake is covered as you pull away, and you stall it.  As it's your left foot that is in the ground the bike will naturally lean to the left. Push bike upright, change feet, fumble for neutral as you are trying to rush it, start engine, engage 1st and then pull away. All this with the average impatient drivers behind you.  Remove the clutch lever, one bolt, feed wires through the hole and into the hole in the headlamp shell, and connect to the two wires which should be already waiting for you. Refit clutch lever, job done. Stall engine.pull in clutch lever, hit the starter and carry on regardless. Have fun.
 hit
Offline Mikep328
« Reply #10 on: August 04, 2025, 09:09:22 AM »
"If your bike is wired correctly, the starter will not work unless the neutral light is on. so disengaging the clutch will have no effect without the switch."
Hmmm.  I guess a previous owner must have disconnected/rewired it since the bike will start in gear with clutch engaged (lever out).  Interesting to me that the owners manual says nothing about that.  I would expect there to be a statement something like, "Motorcycle must be in neutral or have clutch disengaged for starter to operate." Was that switch on all years of the CB400F?  Wondering if maybe it was added later than '76?
If not a previous owner must have bypassed both the clutch switch and the neutral switch.
« Last Edit: August 04, 2025, 09:13:09 AM by Mikep328 »
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
Offline Mikep328
« Reply #11 on: August 06, 2025, 12:45:21 PM »
Turns out...nobody disconnected nuthin'!   I was wrong when I said there was no clutch switch.  I  assumed there was no clutch switch because the function wasn't present.  But the switch was (is)!
The bike had probably sat so long in a previous life that the little plunger in the switch had seized in the closed position. A shot of WD40 released it and now it works as intended.  Nice when a "fix" is so simple!  :)
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
Offline Athame57
« Reply #12 on: August 06, 2025, 12:54:21 PM »
Reminds me of when I could't select first gear for a few weeks. Workshop suggested different oil, and then wanted to pull bike apart.  :o In the end I had a hunch and repositioned gear change lever, bingo, it was cured! ;D
Meanwhile workshop went out of business and new management is there now.  8)
Offline Aye Gee 1977
« Reply #13 on: August 30, 2025, 12:00:47 PM »
If the plunger was stuck home, the electric starter should not operate when in gear.
I recently took the switch apart on the F2 I bought new on 1977.  The contacts were corroded and I spent a happy half day trying to make and fit new ones.  In the end I bought a repro from DSS.  The old one is in the maybe box, in case I forget how frustrating it was trying to fix it.
« Reply #14 on: August 30, 2025, 02:57:54 PM »
Don’t forget the switch will only sit properly in the handlebar switch when it’s oriented correctly. It has a small prong which sits in a groove in the switchgear.
