Author Topic: Overcharging  (Read 14377 times)
Offline Grewth
Re: Overcharging
« Reply #15 on: August 10, 2025, 12:44:09 PM »
Sounds like a good mod, maybe tie it into the kill switch to give full volts at coil as well
Sounds  like a good idea, I'm also thinking that maybe a hidden switch on the relay circuit might give an extra layer of security against theft.
My mate had the ignition circuit on his Reliant Scimitar wired through a relay, wired so you had to hit the secret switch every time you turned the ignition back on.
Saved the car once to my knowledge.
Offline TIM1954
Re: Overcharging
« Reply #16 on: August 28, 2025, 05:57:57 PM »
Adjusted the voltage regulator and that sorted the problem. Thanks for comments.
Re: Overcharging
« Reply #17 on: August 28, 2025, 11:29:40 PM »
