Author Topic: Clutch drag (Pushrod/Cable/Adjustment?) woes CB500k2  (Read 12695 times)
Offline TimS-Orby
« on: August 21, 2025, 05:00:55 PM »
Hi all,
After bowing out of the CB500k2 tinkering for a while, due to family health issues, I’m now back to tentative tinkering here and there.
Many thanks for the help regarding the carb service I undertook, and thanks to Nurse Julie for coming to the rescue with elusive carb parts. In the end that all went surprisingly well, and the bike now seems quite at home with the cleaned and serviced carbs. I’ve yet to do a full carb sync (I treated myself to a vacuum syncing setup), but so far so good, and we have a nice reliable tick-over.
So, it came to the stage where I was actually thinking about the first test run! No luck, I’m afraid. I soon discovered that the clutch was stuck solid. Anyway, after more reading here I managed to encourage the clutch plates apart and breathed a sigh of relief. I reckon it was maybe my fault as I had decided to do an oil change and I left her draining overnight… maybe the clutch plates had chance to drain just that bit too thoroughly?
There has still been no test run, because I have a real clutch drag problem. I had noticed when the bike first arrived that literally all of the free play had been taken out of the clutch cable. Literally zero freeplay, and it took me and all my strength to drag the clutch lever back. When I managed to drag the thing right back to the bars, I could actually drop her into gear with the clutch in without her jerking forward and stalling immediately. However, with the clutch in, and in gear, I could feel her trying to creep forward, and toeing her backward was like rolling over speed bumps! Clearly with clutch lever in it’s still pretty much engaged and, as I said, zero free play in the cable. It’s still the same now, unless I pull the lever all the way back the clutch doesn’t fully disengage. There’s no way I’d be happy to ride with the clutch behaving as it is, or feeling as it does.
Having done more reading here,  I decided to pull the left-side sprocket cover so I could have a look what was going on with the adjuster behind (I’d already tried all the adjustment strategies via the adjust etc). The adjuster looked pretty crappy, but the ball bearing was present and correct there in the thrusting bit. Ball bearing looks very clean and without scratches/flats.
So, I thoroughly cleaned the entire mechanism, spiral thread/splines and all, through roughly re-greased with high temp Moly grease, reassembled everything (making sure to include the ball bearing!), and it made no difference at all. I still have to crank all of the free play out of the cable at both ends to get anywhere near being able to lift the clutch to a level where the bike doesn’t stall when you drop it into gear.
I also thoroughly lubed the clutch cable and it runs freely and is routed as per recommendations here.
So, left-hand cover off again so I could have a look at the pushrod. To my relief it was in one piece, and to my eye it looks… Okay. Photos attached. However, it measures 256mm (at a push, possibly more like 255), and there is significant concavity on the adjuster end, where the ball bearing has been making contact. Now, is this divot in the end of the pushrod really enough to result in such a degree of clutch drag? If we say that this reduces the total throw of the pushrod by 1mm, is that enough to result in the kind of problems I’m having? What does everyone think?
I saw today that DS is actually selling some “Old Stock” pushrods, so I’ve ordered one just for the hell of it. They’ve clearly been in some mechanics drawer for donkey’s, so they’re rusty… but ordering one of those at least made me feel like I was doing something! Here’s the link: https://www.davidsilverspares.co.uk/CB500K2-FOUR-1973-USA/part_334326
Any ideas, anyone. Have I missed anything? Any advice?
Incidentally. In the documentation (such as it is) that can with the bike, I found a receipt from may this year for a “Repro” clutch cable from DS, which I’m assuming is the one that’s currently on the bike. What if this was the wrong cable… if the inner was too long, could that result in the adjuster/actuator not being lifter far enough when the lever was right back to the bars?
I don’t know, and I’m in that lonely place where you’re scratching your head about a job and you’re out of ideas, and need a hug! Lol.  I’m sure you all know how that feels! ;)
Looking forward to your thoughts,
Best,
T
Re: Clutch drag (Pushrod/Cable/Adjustment?) woes CB500k2
« Reply #1 on: August 21, 2025, 05:49:15 PM »
Pushrod looks fine, the adjuster outer can crack and that causes problems but by far the most common problem is a bad or incorectly routed cable unless a po has fitted extra stong springs.
Lubing a cable is a no no by the way
Offline Seabeowner
« Reply #2 on: August 21, 2025, 07:54:47 PM »
Clutch always was a little heavy on the 500, much lighter on the 550. If you have had it apart you should be familiar with adjusting the big slotted adjuster. It is very sensitive to a few degrees movement. I usually ignore the adjustment method in the manual and just play with this until it suits.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Online deltarider
« Reply #3 on: August 21, 2025, 07:57:01 PM »
Is that a CB500K2-A (US)? What handlebars does it have, the high US or the low Europe ones? Reason I ask: Honda had two lengths clutch cables, for the US (suffix -020) and European handlebars (suffix -621). Could it be you have the wrong length clutch cable?
Genuine Honda clutch cables don't need to be lubed. Actually, it is not good for them.
Offline TimS-Orby
« Reply #4 on: August 22, 2025, 04:54:47 PM »
Thanks for the thoughts and advice All. Useful stuff.
I've continued to try adjustments of both cable ends and careful and small increments of the sprocket cover adjuster itself, but there's been no improvement whatsoever.
So, I decided my last resort should be to take my courage in both hands and dismantle the clutch pack itself. In the stuff that came with the bike there was a DS receipt for a clutch rebuild kit from 3 years ago, so I'm assuming that's what's in there now.
Teardown of the clutch has gone fairly easily... no broken springs and seemingly nothing untoward. However, I'm including photos of the plates, the friction plates and the steels in between. A few of them were stuck together a little, but I'm pretty sure it was mostly surface suction. BUT... should the steels be looking like that, or is that old material that needs to be removed from them? I'm assuming they should be pristine (ish) and shiny?
Oddly, the dotted pattern on them doesn't relate to any pattern on the current friction plates between them, so do we think someone used the old steels here, while replacing the friction plates? Advice please ;)
Anything else I need to know relating to these?
I've no measured the thickness of the friction plates yet, but understand I should.
Deltarider.... how do I know if my K2 is a K2 (A)? Is there any way to find out? I discovered it was a K2 from the frame and engine numbers. Just in case, I'm including a could of pics of the bars, but not sure if they will help at all.
Thanks for the help everyone.
Best,
T
« Reply #5 on: August 22, 2025, 05:18:14 PM »
They look like aftermarket handlebars, they appear to be a lot hight than even the USA model bars. Euro/ UK bars are a lot, lot lower than that, almost flat in comparison to those. The cables also look very taught.
« Last Edit: August 22, 2025, 05:20:57 PM by Nurse Julie »
« Reply #6 on: August 22, 2025, 07:41:33 PM »
Yes the sreel plates now have dimples, they are pressed out and if you look closely there is a straight edge and a rounded edge to the splines, all should be same way round but cant remember which way in,
The slant grooves of the fibres go one way but again cant remenber which way, should be in the manual.
Bars look like US bars and if switch wires go inside and fit they would be correct are they reinforcedinbetween the clamp positions where the wiring comes out?
Does the bike have a vin plate on the RH side of the headstock with year details and same number as stamped on LH side of headstock?
With the cables looking that tight neither throttle nor clutch will work correctly
« Last Edit: August 22, 2025, 07:44:20 PM by Bryanj »
Online Oddjob
« Reply #7 on: August 22, 2025, 08:29:09 PM »
The steels are known to buckle if left for some  time. Try testing them on a sheet of glass to see if they are. Severe clutch drag will occur if one or more are.
Look at the cable routing diagram as well, the 500 is very sensitive to cable routing. If everything is spot on the clutch can be a one finger pull, vert few get to be that good though.
« Reply #8 on: August 22, 2025, 08:39:17 PM »
Hiya Ken nice to see your first post back mate!
Offline TimS-Orby
« Reply #9 on: August 22, 2025, 08:47:08 PM »
Thanks for that. Where do I find the routing diagram? Have I missed it in the Service Manual?
T
Offline TimS-Orby
« Reply #10 on: August 22, 2025, 08:50:27 PM »
I'll check on this tomorrow. Definitely a VIN plate on RH side of headstock, and it's the same number as the one stamped into the LH side... I don't remember seeing a date though. I will double-check.
« Reply #11 on: August 22, 2025, 08:59:34 PM »
The US plate states the vehicle conforms to state legistlate in force on a build date, or some such verbiage.
I can get a pic of one for you or post a pic of yours, it sounds like yours is probably a US model and you need the US cables.
There should be build and pdi sheets for the 500 four in ashs dropbox.
EDIT sorry not everything in dropbox and alladins cave links dissapeared at last forum update, not Steves fault!
I think cable routing is in the manual which is downloadable from the dropbox
« Last Edit: August 22, 2025, 09:05:10 PM by Bryanj »
Offline TimS-Orby
« Reply #12 on: August 23, 2025, 10:52:00 AM »
Thanks for that tip BryanJ. Here it is. I feel like I should bake a cake ;)
« Reply #13 on: August 23, 2025, 11:44:59 AM »
Thats def a US bike i would try getting US cables from Mr Silver, he does list them
« Reply #14 on: August 23, 2025, 01:28:18 PM »
IMHO  worth removing the cable and measuring the length of the outer cable, some sellers list cables by length.
Certainly worth getting the cable routed correctly.
