Author Topic: My CB550 Four k1 journey  (Read 19814 times)
Offline Jond99
« on: August 24, 2025, 01:28:48 PM »
Xxx
« Last Edit: May 30, 2026, 12:01:30 PM by Jond99 »
Offline Jond99
Re: My CB550 Four k1 journey
« Reply #1 on: August 24, 2025, 01:36:04 PM »
Xxx
« Last Edit: May 30, 2026, 12:02:02 PM by Jond99 »
« Reply #2 on: August 24, 2025, 01:40:22 PM »
Nice project Jon. Strange pipes, and strange colour too. Good luck with it!
Offline Jond99
« Reply #3 on: August 24, 2025, 01:47:24 PM »
Xxx
« Last Edit: May 30, 2026, 12:16:07 PM by Jond99 »
« Reply #4 on: August 24, 2025, 04:55:32 PM »
Same pipes as 500 standard, Delkavik is good as complete kit
« Reply #5 on: August 24, 2025, 05:33:27 PM »
From dss uk site, everything will transfer but new cables and top brake hose would be better.
« Reply #6 on: August 24, 2025, 08:19:52 PM »
Routing of fuel tubes is prone to cause issues. I envy those little clamps though. Where can I get them?
Offline Jond99
« Reply #7 on: August 24, 2025, 09:43:27 PM »
Xxxx
« Last Edit: May 30, 2026, 12:14:31 PM by Jond99 »
« Reply #8 on: August 25, 2025, 11:08:32 AM »
Thanks.
Yes, pipes are not OE which was a shame, I’d like to get something more like the original 4 into 4’s. Colour, to my none expert eye looks pretty close to Flake Sunrise Orange from the pictures I’ve seen, possibly it isn’t.
Sorry Jon, the light and the pictures themselves are not the true representation of the colour.
« Reply #9 on: August 25, 2025, 11:25:59 AM »
They are used on automotive applications, common on German cars, often on Audi VW vehicles. Small "Knipex twingrip" pliers make them very easy to move around.
Alternatively, I like these type "single ear stainless hose clamps" that have a very compact profile/space requirement/broad clamping surface amalgam to work exceptionally well with small hoses.
A little more difficult to use, should have a dedicated "setting" tool .... but can effectively be set with a old style nail puller type plyer to "crimp" them.
With those type, you can latch them, slide into place and gently squeeze them to closure (it bends two kink into that ear shape) which makes one of the most secure and neat hose clamp arrangement I've used. They are super neat and use, effectively, an uninterrupted band to gently caress  ;D the rubber hose uniformly all around it's circumference.
« Reply #10 on: August 25, 2025, 11:54:45 AM »
I bought some on ebay, I think it was a selection box of different diametrs.
Offline Seabeowner
« Reply #11 on: August 25, 2025, 07:42:14 PM »
If you want throgh the bars wiring check with DSS that they have the holes. I used the ones they listed for the 550F which did have holes but now seem OOS. These are for a 750 so not sure if ok, but do have the holes:
https://www.motorcycleproducts.co.uk/chrome-78-handlebars-25-rise-holes-for-wiring-honda-cb750k/1/015257
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline Jond99
« Reply #12 on: September 20, 2025, 10:51:38 AM »
Cxxx
« Last Edit: May 30, 2026, 12:02:37 PM by Jond99 »
« Reply #13 on: September 20, 2025, 11:02:18 AM »
They could be unused connections that are only used in certain countries. One common wiring loom makes commercial sense and several sohc models from that time have them.
« Reply #14 on: September 20, 2025, 11:10:02 AM »
Do all the electrics work as they should?
Is the brown a permanent live or only when the ignition is on?
Possibly for other markets as has been said,
I know sometimes the Horn is earthed at the frame fitting, sometimes depressing the horn button earths it at the switch.
« Last Edit: September 20, 2025, 11:14:26 AM by McCabe-Thiele (Ted) »
