Author Topic: what fits on this bracket  (Read 6287 times)
Offline exvalvesetdabbler
« on: August 25, 2025, 12:41:30 PM »
This part (147) has the hook for the rubber strap that tidies up the wiring harness, but I don't know what the bit that sticks out is for. Looks similar to the bit that the indicator relay rubber mount attaches to.
Regards
Dave
« Last Edit: August 25, 2025, 12:43:20 PM by exvalvesetdabbler »
Re: what fits on this bracket
« Reply #1 on: August 25, 2025, 01:31:27 PM »
This should help, its to tidy up the wiring area on a 400/4
breather routes (1) by Macabe Thiele, on Flickr
« Reply #2 on: August 25, 2025, 01:54:01 PM »
It's for the speed sensor on JDM models, but Honda used the same bracket on all world market models.
« Reply #3 on: August 25, 2025, 03:16:05 PM »
Thanks Julie, explains the chosen description in the parts book.
Thinking of using it for a small electronics module.
Regards
Dave
Offline Athame57
« Reply #4 on: August 25, 2025, 03:49:19 PM »
I wondered why it was referred to as a 'Stay, speed unit' on CMSL, it made precious little sense to me at the time. It was one of the many bits missing from Elen when I got her seven years ago. I got one from DSS (part # 38555377000) and it went rusty very quickly.  ::) So if you get one it helps to paint it before you fit it.  8)
« Last Edit: August 25, 2025, 03:52:07 PM by Athame57 »
1978 CB400F2 named Elen.
« Reply #5 on: August 25, 2025, 05:57:20 PM »
I zinc plated a spare one recently when I did all the clock bases, but then forgot to swap it out when I installed the new horn😡
George, how is Elen, did you get to the root cause of the problem?
Regards
Dave
Offline Athame57
« Reply #6 on: August 25, 2025, 08:44:46 PM »
She needed a rebore, Bryan is doing that for me and getting new pistons from Japan, work in progress!
