Author Topic: Think it's an oil jet  (Read 15541 times)
Offline scutter
« on: August 30, 2025, 10:53:32 AM »
Hi,
Whilst stripping the engine for rebuild/painting, thids appeared on the shed floor!!   Any ideas where it's come from, looks like an oil jet.
Thanks in advance.
Dan.
Re: Think it's an oil jet
« Reply #1 on: August 30, 2025, 11:19:53 AM »
Yes, that's an oil jet.
Offline scutter
« Reply #2 on: August 30, 2025, 11:24:18 AM »
Thanks, where exactly can I refit it?
Dan
Offline DomP
« Reply #3 on: August 30, 2025, 11:55:16 AM »
May depend on model but on 550s they are between the cylinder head and lower cases.  Make sure you replace it the right way up!
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
« Reply #4 on: August 30, 2025, 12:24:38 PM »
It may be fine detail, but relevant none the less, they are often called "jets" but are in function an oil "restricting" device.
The crankshaft, mains, big ends etc .... all exposed to full delivery/pressure from the oil pump directly .... this to effectively lubricate at designed for attribute.
The restricting "jets" drop that distribution characteristic to supply camshaft at lower rate as the high pressure etc is not needed.
Leaving them out will give excessive supply to top end of engine BUT then starve the crankshaft of its intended rate in supply. Very important, in other words  ;D
« Reply #5 on: August 30, 2025, 02:46:27 PM »
Yes one each side at base gasket, also act as locating dowel and only goes one way up
« Reply #6 on: August 30, 2025, 03:00:57 PM »
Make sure it’s not blocked before fitting. Hold it up to the light and look down it.
