Author Topic: Tyres  (Read 7965 times)
Offline David_N
Tyres
« on: September 01, 2025, 09:37:31 AM »
I'll soon be reaching a point where I'll be wanting to road test my 550k 4.
The front tyre is a brand new ContiGo 3.25 - 19 while the rear is a knackered 120/90 18 Cheng-Shen
Can someone please advise me on what tyre size the bike should have to match the front? I don't think there's any point throwing a perfectly good front tyre in the bin.
Re: Tyres
« Reply #1 on: September 01, 2025, 09:56:59 AM »
The size should be 3.50 x 18,
But they are difficult to get
I fit 4.00 x 18
At present have a Bridgestone BT46,
it suits me
Re: Tyres
« Reply #2 on: September 01, 2025, 10:56:32 AM »
As John says 3.50 x 18 but if you cant get that 4.00 x 18 Conti K112 i think
Offline exvalvesetdabbler
Re: Tyres
« Reply #3 on: September 01, 2025, 11:41:39 AM »
Dunlop k82 is still available in 350-18, Has a similar tread pattern to the old tt100.
Regards
Dave
Re: Tyres
« Reply #4 on: September 01, 2025, 01:56:40 PM »
Ah the TT 100 3.5x18 is equivalent to the English 3.25x18, you need the 4.10x18 to be same as English 3.50x18.
Confusing i know but every person in a dealers was rammed with the info when the TT 100 came out
Offline David_N
Re: Tyres
« Reply #5 on: September 01, 2025, 01:59:05 PM »
Will these suggestions be okay to mix with the continental contigo that's goes to the front?
Re: Tyres
« Reply #6 on: September 01, 2025, 02:03:33 PM »
Personally i wouldnt i would get a conti
Re: Tyres
« Reply #7 on: September 01, 2025, 02:03:42 PM »
I wouldn't fit a TT100 ,they were reputed to have a triangular profile,
Could cause issues
Fit a standard rounded profile tyre
The BT46 or Conti should work
Re: Tyres
« Reply #8 on: September 01, 2025, 02:07:03 PM »
100/90x18 is euivalent
Offline flatfour
Re: Tyres
« Reply #9 on: September 01, 2025, 03:05:31 PM »
I've bought a good few Honda 500's both new and used, and always fitted TT100's to them, as I have with the Benelli Sei and the CB750's. They're standard fit on the Trident, too.
To me, they are the perfect tyre, except for wear rate, which can often seem a little high. I usually manage around 4000 miles from a rear, and more from a front tyre. I've ridden friends bikes of the same type as mine fitted with modern tyres that appear to have a lower profile, and they just feel odd, perhaps because of my familiarity with TT100's.
When I was buying new in the 1970's, the dealer that I used most would always recommend a change to TT100 tyres, always 4:10 front and rear, although the 3:60 was available for the front, even then.
Perhaps it's just a habit that's stayed with me ever since, but I've never seen the need to move away from them?
Re: Tyres
« Reply #10 on: September 01, 2025, 05:51:47 PM »
