Author Topic: CSMNL Exhaust for CB550 K3  (Read 26163 times)
Offline Gromitdog
« on: September 01, 2025, 04:22:31 PM »
By chance would anyone have the fitting instructions for a set of exhausts from CSM for a CB550 K3 all I got this morning was a printed sheet from the CEO saying to follow the instructions on how to fit them I gone through all the boxes and No instructions in sight only the invoice, Very disappointing  considering I just spent over £1200 on them, I have emailed them and it may take 5-7 days to get a reply I am not holding my breath they actually have a set of instructions
KEEPING IT SHINY SIDE UP IS ALWAYS A GOOD RESULT ON A RIDE OUT
Re: CSMNL Exhaust for CB550 K3
« Reply #1 on: September 01, 2025, 07:58:41 PM »
Do you mean the four pipe silencer system Nigel?
If you do page 52 &  53 of my build below covered this as I had no instructions.
« Last Edit: September 01, 2025, 08:05:30 PM by McCabe-Thiele (Ted) »
Offline Gromitdog
« Reply #2 on: September 01, 2025, 09:03:18 PM »
Hi Ted
Yes I do I will have a look at those pages cheers, Hope all is well with you. I have to say I think cam take the "mick" charging what they do for these and can't be bothered to put a sheet of instructions in 😖
Cheers Nige
Offline Gromitdog
« Reply #3 on: September 02, 2025, 04:46:06 PM »
CSM NL have replied they don't do any instructions  for fitting these exhaust system for a CB550 K3 But are happy to charge over 1k for them 😖, They are not quite the same as Teds system  but it still involves 4 separate exhaust pipes,
The boxes which each exhaust pipes come in are marked up A, B, C, D, would I be right in thinking
A =L/H pipe N01, B + L/H pipe N0 2 and so on as CSM are of no help what so ever,  Can anyone tell if I am on the right track ? Or has anyone had any experience in fitting a 4 pipe exhaust system to a K3 that they have purchased from CSM
« Reply #4 on: September 02, 2025, 05:50:55 PM »
If you look at the photos on my 500 project you should be able to identify number 1 & 2 pipes easily. I think A & B were 1 &:2
Once you loosely fit pipe 2 first, the bracket fits on the inside of the foot rest mount. The bracket for number 1n pipe fits on the outside of the footrest frame fitting.
My 4 brackets were marked as per my rebuild posts.
I would be surprised if the 500 is much different.
« Last Edit: September 02, 2025, 05:53:46 PM by McCabe-Thiele (Ted) »
Offline Seabeowner
« Reply #5 on: September 02, 2025, 07:01:40 PM »
If they are like the originals I remember you have to fit the pipes for 2&3 first. They are the ones with the two threaded studs. Fit them to the bracket and hang them. Do not tighten everything too much at this stage. Then the pipes for 1 & 4 which have one threaded stud and one plain stud can be hanged and fitted into bracket. Then move to your satisfaction and tighten the lot.
They were much easier that the four pipes on the earlier 500/550s.
Or if you bought the earlier pipes then ignore all that. They may be tricky to fit a K3.
« Last Edit: September 02, 2025, 07:07:28 PM by Seabeowner »
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #6 on: September 03, 2025, 02:07:31 PM »
Hi Nige, has the pipes not got the stamping on them stating iL and oR etc? Mine were a number of years ago but they were a bitch to fit. I used ratchet straps so they would eventually fit. I believe they were a prototype set I think that were pre - production. There were quite a number of years they were no longer being produced.
Offline Gromitdog
« Reply #7 on: September 03, 2025, 02:57:21 PM »
Hi Johnny & Seabeowner & Ted
Yes I have since had a look and have found the ones marked A & B on the boxes ( I which I take are L/H 1 & 2 ) do have the following code stamped on them of L1 & SL only trial fitted so far and S1 seems to be very close but L1 miles away more tea needs and some deeper investigation I think , Might get the C & D and just see if they fit better as I had to have some welding done to the frame on the L/H side just fwd of the swing arm area which might a have effect on exhausts 1&2 ?????
Ted has suggested the same to fit 2&3 first then hang 1&4 slave together loosely then tight up when happy
will have a look later this week as Sheila is hinting I need to fit some acoustic panels that are lying on the living room floor at the moment 😂 so you can guess which order the jobs will be in 😂😂😂😂
Thank you for all your help on this so far guys
Offline Rozabikes Tim
« Reply #8 on: September 03, 2025, 04:10:14 PM »
Are the acoustic panels for when you fire the 550 up?🤔😳🙃
« Reply #9 on: September 03, 2025, 06:10:41 PM »
I'm assuming you can identify pipe 2 from the position of the bracket on the silencer section.
What is the situation when you just try to fit the pipe for cylinder 2 ?
Is it that you aren't sure if you are using the right bracket ?
Using a bungee strap at the end of the silencer attached to the frame can help you get the first pipe in place, be it no2 or no3.
Are you sure you removed the old front pipe seal rings from the cylinder head exhaust ports ?
« Last Edit: September 03, 2025, 09:14:31 PM by McCabe-Thiele (Ted) »
Offline Gromitdog
« Reply #10 on: September 05, 2025, 08:11:51 AM »
Hi Ted
I am sure I have the correct brkts for the fitment of the exhausts for a K3 I have removed the old copper gaskets from the cycling head, As you suggested I am fitting N02 pipe first then hanging pipe N01 to the brkt . Pipe N0 2 seems to need to go rearwards more and upwards more (A) to clear the side stand when in transit and (B) rearwards to aline with the brkt hole on the frame. Pipe N01 seems to be about right .
This is as far as I have got at the moment due to other work that has to get done in the living room ie the acustic panels 😊
I might try seeing how 3&4 fit before coming back to 1&2 as I mentioned I had to have some welding done to the area just fwd of the swing arm on the L/H side of the frame.
Will update after the when when I got these panels on the wall hopefully, Thanks again for all the help and advice on this matter most appreciated.
Nige
« Reply #11 on: September 05, 2025, 01:54:07 PM »
If its the same as 500 the one on side stand side goes what feels like the wrong side of the sidestand, hope that makes sense
Offline Gromitdog
« Reply #12 on: September 08, 2025, 03:38:20 PM »
Big Thank you to you all for your help and advice on how to fit these K3 exhausts as was not obvious to me how the L/H side fitted, I have been out to the garage this afternoon to see if I could slave both sides on and if any adjustments where needed, The L/H side just need the main brat filing a bit to give the inner brkt bolt some movement. The R/H side main Brkt needs a bit of filing on the main Brkt to get dowel location hole to fit on the outer exhaust as its tight to fit.
Hope that makes kinda sense as its hard to explain
« Last Edit: September 08, 2025, 03:49:29 PM by Gromitdog »
« Reply #13 on: September 08, 2025, 05:18:50 PM »
My center stand was rather close to the silencer, I used a nut & bolt with a rubber on the end to ensure clearance.
Offline Gromitdog
« Reply #14 on: September 09, 2025, 07:00:18 PM »
Hi All
As I mentioned on yesterdays update on fitting my K3 exhuast system which other than a bit of filing on the rear main brackets it should be good to go for a final fit tomorrow 🤗 🤗  However the outer exhaust which has 1x 10mm nut and a location pin I can't seem find a nut to fit it 😞 I have put a thread gauge on it and it seems to be  10 x 1.25mm it will only go on 1/2 a turn before  feeling like its cross threading The thread has been chromed which might be the cause of the nut not wanting to go on correctly.
Any thoughts please
