Author Topic: Points, Advance retard mech  (Read 6217 times)
Offline SandyRob
« on: September 04, 2025, 08:56:24 AM »
Hi, I am having trouble with my advance retard mechanism, it is a nd and nd points plate system, I have a Tec advance retard mech, so my question is will the tec adv/ret work with the nd points plate? or do I need a Tec points plate, if so will the points and condensers from my nd plate fit the Tec plate?
Phew!
Rob. Honda CB400 Four 1978.
Offline Mikep328
Re: Points, Advance retard mech
« Reply #1 on: September 04, 2025, 12:11:46 PM »
When I removed the e-ignition on my 400F to reinstall OEM points I was TOLD that you have to match the advance unit and points plate.  IOW, they both have to be either TEC OR ND.  I can't verify that this is really true  - maybe someone here can -  but I had an ND advance unit so I bought an ND plate/points.
Frankly, as long as the advance cam can successfully contact the points' rubbing block and still allow proper gap adjustment, I don't see what difference it would make but I didn't want to find out the hard way and have to buy another points plate...
Mine:
1976 CB400F
1973 Norton 850 Commando
2015 BMW R9T
2017 BMW R1200RS
2021 Moto Guzzi V7 Special
Wife's:
2015 Ducati Diavel
2019 Honda Africa Twin
2019 Honda NCT750
« Reply #2 on: September 04, 2025, 01:08:28 PM »
As both are available seperately you should be able to fit any advance unit with any points plate, to the best of my knowledge all the sohc fours use the same points plate.
Parts from the different advancers will not interchange
« Reply #3 on: September 04, 2025, 01:17:01 PM »
IIRC if you use the DS electronic ignition on a 400 there are two different versions depending if your advancer is ND or TEC.
The reason for this is the boss for the advancer is a different size fitting so the rotor will not fit.
Offline Mikep328
« Reply #4 on: September 04, 2025, 02:57:02 PM »
AH!   THAT (re DSS E-ignition/advance unit) is what I was told and I mis-remembered it being about the points ignition!!!  Sorry, Sandy!!
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
Offline SandyRob
« Reply #5 on: September 16, 2025, 08:13:02 AM »
hHi, thanks for the replies, got it sorted now, the pin on the back of the advance retard mechanism was loose, I also reset the float heights and it goes alot better. Thanks everyone.
