Author Topic: Swing Arm Bushes  (Read 24617 times)
Re: Swing Arm Bushes
« Reply #30 on: December 31, 2025, 06:22:51 PM »
Tourmax kit.
https://www.ebay.co.uk/itm/125392834805
Cheaper to go this way that retain original setup and they should improve the handling as they stiffen up the backend.
Offline Seabeowner
« Reply #31 on: December 31, 2025, 07:39:40 PM »
The original 750/500 collar is available from DSS for a pricey £109 or from CMS a bit cheaper, but then extra for shipping if you want to go that way. Have you dismantled it and checked the parts? But as Bryan pointed out the collar is often worn.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline Murf
« Reply #32 on: December 31, 2025, 07:42:16 PM »
Those collars were around £82, €93 euro when I got mine in September 😳  which I thought was expensive then + about £30 for the bushes . So I think you are right, the Tourmax kit seems to be the way to go now.
« Reply #33 on: January 01, 2026, 02:30:49 PM »
SOLD.....I have a new Tourmax 500/750 kit here. Had it a long time, no idea where the box is. Owes £75.00, so £75.00 + post at cost if anyone is interested. I think I offered it here a few years back but no one was interested.
« Last Edit: January 12, 2026, 02:54:51 PM by Nurse Julie »
Offline Grewth
« Reply #34 on: January 05, 2026, 01:50:48 PM »
Just my 0.02c.
If those are needle roller bearings,  I wouldn't touch them with a barge pole.
Every bike I've ever had with needle rollers in the S/A has let water in and then the rollers have rusted and destroyed the expensive shaft.
That was despite the presence of grease.
Plastic or Bronze every time in my opinion.
Maybe there's a tiny bit of play but they last for donkeys years with regular greasing
« Reply #35 on: January 05, 2026, 02:05:45 PM »
Surely that points more to the sealing system than to the bearings? I've got another Honda that uses needle rollers in the SA and that is perfect, no water ingress at all. The washers you can see in the kit are also needle rollers as well BTW, they allow the shaft to turn if needed. If your using a central external grease nipple like the 550F has then the entire swinging arm tube should be full of grease including the needle rollers. A couple of squeezes of the grease gun per year should keep everything in good order.
The other problem Grewth is the lack of availability of the internal collar and the cost IF you can find one, plus TBH the 500 SA greasing system is flawed, very easy for it to block up and no grease then gets to the surfaces, hence why the collar and bearings wear so easily.
