Author Topic: Mixture screw spring CB550K3  (Read 1069 times)
Offline Harold 400/4
« on: September 29, 2025, 08:27:05 PM »
Does anyone have a spare mixture screw spring I could buy pls?
Carbs are PD46A and I’m currently overhauling. Took the 4 mixture screws out, and one of the springs is in two pieces. All the other parts seem OK other than the O rings which I’ll renew.
Many thanks
Harold
Harold - I was just about to list these on eBay as a spares set for £60. Probably more than you want to spend, but might be a good option as a spares resource - you could re-plate/replace all of the hardware over time and swap in/out on your set. Happy to do them for £50 to a forum member. The bodies are probably too corroded to be salvegable.
« Last Edit: September 29, 2025, 08:41:43 PM by JamesH »
Re: Mixture screw spring CB550K3
« Reply #2 on: September 30, 2025, 06:59:30 AM »
Hi James. Many thanks for the offer, but as it’s just the one spring I need, I will decline.
Good luck with the sale.
« Reply #3 on: September 30, 2025, 07:07:53 AM »
Hi Harold, I have one, just pm your address and I’ll pop it in the post.
« Reply #4 on: September 30, 2025, 04:29:31 PM »
Thanks Johnny. PM sent 👍
