Author Topic: Ultrasonic cleaner  (Read 8130 times)
Offline Ken4004
Ultrasonic cleaner
« on: September 30, 2025, 08:11:48 AM »
Can anyone recommend a decent ultrasonic cleaner for carbs etc, I did have one a few years ago and it was a cheaper Chinese device,
It did clean the parts but the results were not as good as I expected so I sold it, this time I’ll spend a little more money and try and find a better quality product which will achieve the desired results.
Offline Bloggs
Re: Ultrasonic cleaner
« Reply #1 on: September 30, 2025, 11:29:59 AM »
Hi,
Have a look at Allendale Ultrasonics, a wide range of machines AND the fluids to go in them.
Can recomend the carb cleaning fluid.
Not the cheapest but good quality.
Michael
« Reply #2 on: September 30, 2025, 11:59:18 AM »
I agree with Bloggs the Allendale cleaning fluids are excellent.
As regards how effective Ultrasound cleaners are I think my expectations were relatively low from my Chinese Cleaner.
I bought one that was a good sized tank so it would take a Carb body etc.
I always did some external pre-cleaning by washing the carbs with petrol and a little scrubbing as required.
Likewise a blocked jet might need some thin wire to start clearing out the blockage. Some parts like a carb bowl would have bits of adhesive or gasket material stuck to them. When needed a soft brush would remove loose bits after a first clean.
With brass parts I put them in a jar with white vinegar then immersed the jar in the Ultrasound cleaner. As my cheap Ulrasound Cleaner took ages to heat up I added off the boil water to shorten the heating up time.
The only fault on my cheap cleaner is the control  buttons that are covered with a sort of plastic have cracked so I have to ensure I dont let the control panel get wet, sticking a polythene cover over the panel has worked so far.
I could be wrong, dont expect too much improvement from a more expensive unit in terms of cleaning ability, you are paying for longevity I suspect. My Chinese unit still works, I bought it during Covid lock down IIRC.
Offline neat street
« Reply #3 on: September 30, 2025, 03:40:22 PM »
Mine is by Creworks and can heat as well aas ultra, works very well for everything including degreasing as long as you use the right cleaner for the job. had it for anout 1 year and would recomend.
CB500 1975
CB750F 1976
KLX250 1983
Lambretta SX200 1979
Mini Mayfair 1984
Offline Ken4004
« Reply #4 on: September 30, 2025, 06:56:40 PM »
Ok thanks guys will do a little research
Offline ST1100
« Reply #5 on: September 30, 2025, 07:03:57 PM »
I'd recommend not exceeding 60°C with them, had some discoloration on caliper paint at 80°C...
Besides this, absolute brilliant kits...
I use DI water which I preheat in an electric kettle (the heater in the ultrasonic would take quite a while till 60°C by itself, but keeps the temperature constant during the cleaning times), dosage of designated ultrasonic solvent as by instructions on the bottle (mine says 'for carburetor cleaning'), 30 minutes...
Also a set of stainless cleaning baskets/mesh balls comes handy, saves having to fish for any tiny items like screws or jets in the bilge:
https://www.amazon.de/dp/B0C33T2685?language=en_GB
STOC #637
Offline SumpMagnet
« Reply #6 on: September 30, 2025, 08:20:35 PM »
I bought a cheap Chinese generic, and it works OK, provided you buy proper cleaner. It came with some cleaner, which was aimed more at jewellery and the like, and that wouldn;t shift serious muck. Better cleaning solutions gave me a ..er...better cleaning solution!
CB750F2 - in pieces
