Author Topic: tappet cover o ring size  (Read 10594 times)
Offline exvalvesetdabbler
« on: October 06, 2025, 07:08:06 PM »
Starting to work through a laundry list of minor maintenance tasks,one of them being oil weeping from one or more tappet covers. O rings are probably original as I have not changed them in the 45 odd years I've had the bike.
Does anyone know the correct size, parts book only mentions 30.8 .
Nearest I can find is 31 ID x 3 cross section.
Looking at some of the ridiculous prices some folk are charging for genuine ones, it might be cheaper all round to order new covers from China that come with o ring.
Regards
Dave
Re: tappet cover o ring size
« Reply #1 on: October 06, 2025, 07:52:21 PM »
30.8 x 3.2 is the correct size. However they ain’t available off the shelf, special order of 500 minimum is the general rule. Most sellers tell you they are the correct size but they’ll be 31x 3.0 normally. Sometimes they work and sometimes they don’t. Tappet covers are generally ok but the same ring is used in the 500/550 inlet ports and it’s very important they seal well.
There are 12 of them in a genuine top end gasket set so I use those just for the inlet ports and use close enough for the tappet covers.
I’m betting the chinese covers are using close enough as well.
« Reply #2 on: October 06, 2025, 10:29:25 PM »
Thanks Ken,
At least my measurements and % gland fill calculations agree with what you're using.
Regards
Dave
« Reply #3 on: October 07, 2025, 06:57:00 PM »
Found some in FKM,
OD 37mm CS 3.1mm  £5.67 for ten.  I'll report back once received and fitted.
Regards
Dave
« Reply #4 on: October 07, 2025, 07:17:55 PM »
I did float the idea of having some specially made in Viton but I was warned that the hardness of them could mean they wouldn’t crush properly. Personally I didn’t believe that but I thought I’d repeat it just in case.
I may have some made the correct size if my claim pays out enough. Won’t be any time soon though.
« Reply #5 on: October 07, 2025, 07:24:43 PM »
I sell them in Nitrile and a % of all my sales go to run this forum. I've sold thousands of them and we also fit them to all our own CB SOHC 4'S. Viton shears too easily for this application
« Reply #6 on: October 07, 2025, 07:25:20 PM »
Ease of compression depends on the hardness.  Shore 70 is the norm for most stuff.  When I worked  we would use SH 70 Viton on underwater housings rated to a few thousand meters water depth. A bit of fluff or debris during assembly was the biggest risk.
Regards
Dave
« Reply #7 on: October 20, 2025, 04:34:47 PM »
New o rings dropped through the letter box today.
They seem ok to me.  Only time will tell after a good soaking in hot oil.
Screw in finger tight, then about 3/4 turn with a socket until the caps bottom out and tighten.
Regards
Dave
« Reply #8 on: October 20, 2025, 05:05:42 PM »
Are they silicone?
« Reply #9 on: October 20, 2025, 05:43:41 PM »
Too hard for silicone.  They're sold as fkm though they could be hydrogenated nitrile as some manufacturers use green for either.
The main point of green is to differentiate from nitrile or Edpm in production environments where using a standard o ring could cause a disaster or be short lived.
Hardness is on par with shore A70.
Regards
Dave
