Author Topic: Spoke Material - Before I buy new Spokes.  (Read 517 times)
Offline Eldrick
« on: October 15, 2025, 06:25:05 PM »
I am going to buy new spokes for my '75 400f and Apart from DS I see Central Wheel Components (CWC) also sell spokes and list three different 'finishes' for want of a better word.
Galvanised steel was the traditional material for spokes, although stainless steel is now more popular and gives a better longer lasting finish.
Polished stainless steel gives spokes a chrome-like appearance, but without the same level of maintenance.
Single butted spokes are only produced in stainless steel and can only be supplied polished.
Q. Would I be right to think that the Single Butted ones are 'better' insofar as they will stay bright, be longer lasting as well as being overall less cleaning or just easier to keep them looking good?
What I actually want is for the bike to look mostly original and I am not sure which spoke set would accomplish that aim.
There is also two types of nipples listed, with the suggestion that the Single Butted spokes would require the Brass-nickel plated nipples. No real question there just want to be 'kept right' before I buy.
Q. Spokes are listed by size, 16", 17", 18", 19" and 20" How do I measure my current rims to ensure I get the correct spokes?
I can only presume that the rims on the bike are original.
Also, any advice on 'rim tape' would be helpfull too.
K
1975 Honda CB400f - Red
Re: Spoke Material - Before I buy new Spokes.
« Reply #1 on: October 15, 2025, 06:50:48 PM »
Polished stainless are what we always use.
The butted bit relates to the 'thickness ' at each end, off the top of my head I can't remember if 400's use non butted or single butted but someone will answer you on that. They definitely aren't double butted, I can remember that 😁
If you tell CWC what bike it's for, they supply a kit.
Yes, you need rim tape.
« Last Edit: October 15, 2025, 06:53:57 PM by Nurse Julie »
« Reply #2 on: October 15, 2025, 07:49:48 PM »
I think Silvers may sell decent pattern one in bright zinc ..rears are same as CB250K and they deffo do those in decent quality pattern.both fronts and rears single butted on 400F. Personally and for originality I have never used stainless...but that's just me wanting originality.
« Reply #3 on: October 15, 2025, 08:40:51 PM »
If you don't ride your bike on salty winter roads and keep your bike clean the galvanised or zinc plated spokes will last just fine. Stainless steel is a bit harder than mild steel and more brittle. They are slightly more prone to breaking, occasionally that can be a problem.
Other suppliers are Devon Rim Company and Hagon.
Offline ozzybud
« Reply #4 on: October 15, 2025, 08:41:19 PM »
If you want the correct yellow nipples buy the zinc kits from CMS. They are a perfect match to the originals. DSS has silver nipples.
1976 Z50 YELLOW
1970 CT70 BLUE
1971 CT70H ORANGE
1972 CT70H GREEN
1973 CL200 BLUE
1973 CB350F RED
1975 CB360T RED
1975 CB400F BLUE
1975 CB550 ORANGE
1976 CB750F RED
« Reply #5 on: October 15, 2025, 09:59:59 PM »
Seems pot luck with Silvers ..some are silver some chromate yellow. They have crosshead nipples as well ..originals were just slotted.
Offline Murf
« Reply #6 on: October 15, 2025, 10:25:09 PM »
I would also go for stainless steel ones just because with the odd polish now and then they will stay looking good forever.  Also the zink plating you get now days just isn’t very good and often very thin.
The spoke size 16” 18” etc just refers to the spokes length and not the wheel diameter so measure the spokes your wheel now has and get the same. Somewhere like Central Wheel will probably know what size spokes you need if you tell them what bike it’s for.
« Reply #7 on: October 15, 2025, 10:25:52 PM »
Had this question been asked this morning I could have gone out into the garage and checked my original 400f to see if the spokes are butted or not. Alas my 400f left the garage for the last time late this morning. I rode it the 50 miles to its new owner. It will be taking pride of place in his dining room following a clean (I drained the fuel tank when I got there).
I can definitely advise the spokes were galvanised, had yellow nipples and the DID logo in the centre of the rim.
1976 Honda 400/4
« Reply #8 on: October 16, 2025, 09:14:19 AM »
Having suffered with rusty spokes on my CB750K1 and my FI, when I re rimmed the F1 I went for stainless and have never looked back since.
Offline exvalvesetdabbler
« Reply #9 on: October 16, 2025, 02:18:51 PM »
OEM spokes have a thicker portion towards the hub.  Nipples are zinc yellow.
Regards
Dave
Offline Eldrick
« Reply #10 on: October 24, 2025, 11:47:08 AM »
Should I replace the rims?
They look like this...
« Reply #11 on: October 24, 2025, 11:59:16 AM »
Looks like quite deep rusting around the spoke nipple holes. Not saying these are toast but if it was me I would buy a couple of new rims.
Offline Eldrick
« Reply #12 on: October 24, 2025, 12:01:21 PM »
I was thinking that too and its not like they are very expensive either, said with my better safe than sorry head on...
« Reply #13 on: October 24, 2025, 07:21:26 PM »
This is still available ..modern DID front .. almost half Silvers price.
https://www.sohc.co.uk/index.php/topic,32190.0.html
Offline TrickyMicky
« Reply #14 on: October 25, 2025, 09:24:40 AM »
Definitely new rims if you are able. In the past  I have suffered punctures from flakes of rust piercing the tube, and on one bike, the rust in one spot weakened the rim just enough for the  spoke tension to pull the wheel out of true. The bonus of course, is a pair of new wheels with new spokes really looks the biz.
