Author Topic: Carb balancing  (Read 10527 times)
Offline TrickyMicky
Re: Carb balancing
« Reply #15 on: November 02, 2025, 09:09:50 AM »
Yes good bit of kit a carbtune, i find with my 550 that I have to use it upside down to get the readings to move, why is this?
You've probably acquired one that was for the Australian markey??
Offline Ken4004
Re: Carb balancing
« Reply #16 on: November 02, 2025, 09:43:42 AM »
I noticed at first that I wasn’t getting any readings and discovered that you really need to get the carb tune as close to vertical as possible otherwise you are getting resistance from the indicators rubbing on the inside of the tubes, once vertical you get accurate and responsive readings.
Offline DomP
Re: Carb balancing
« Reply #17 on: November 02, 2025, 12:55:38 PM »
Probably with my luck sometimes😀  they do mention in the destructions that you may need to use it upside down but seems odd that it does put on a 350/400 but on my 550 it does
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Offline JezzaPeach
  • CB500/4 K1 1972 gold
Re: Carb balancing
« Reply #18 on: November 05, 2025, 08:37:57 AM »
As a side note after many months I found my throttle’s intermittent ‘soggy’ blip was likely due to some of the floats being too high causing excess fuel to be sucked through, even though they seemed to be at the 22mm position. It was ok during faster running, when fuel was getting used up, but slowing down with the throttle more closed, the excess fuel was building up and getting sucked through when subsequently blipping e.g. approaching a roundabout.
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
