Author Topic: How to paint the letters on light and kill switch control  (Read 6129 times)
Offline Alexgill2001
« on: November 11, 2025, 08:43:17 PM »
Evening all, I have wanted to recolour the red writing on the right hand light and kill switch control. Initially I used acrylic paint and a cotton bud to fill the embossed letters, however when I went to wipe the surface it removed the black paint!! Argh!!
I then took it all back to bare metal, primed it and then sprayed it black (oil based paint). Used the red acrylic again and it again reacted and removed the black as above (I didn't realised oil and acrylic didn't mix!).
Starred again, bought red from the same company as the black paint (oil based) and yet again after wiping away it removed the black!!
Any one have any tips and/or what paint to use for both the black and red that won't react?
Thanks!
Online McCabe-Thiele (Ted)
Re: How to paint the letters on light and kill switch control
« Reply #1 on: November 11, 2025, 10:37:11 PM »
Had the paint fully hardened?
« Reply #2 on: November 11, 2025, 10:43:40 PM »
I got mine ceramic coated in satin black. Filled the letters etc with red paint and wiped off excess. It seems to be impervious to thinners and brake fluid. Cost me £5 a half casing at the time. Probably £10 now.
« Reply #3 on: November 11, 2025, 10:46:40 PM »
Paint with PJ1 satin black. Bake at 150 deg C then paint with Humbrol enamel.
« Reply #4 on: November 12, 2025, 06:51:26 AM »
Thank you for the advice so far, looks like I'll have to take it off/apart to get it in the oven! Can I ask, is there any advice to take it apart? Do I have to cut some cables?
Currently I've managed to tape up and cover the whole bike to avoid over spray!
Offline neat street
« Reply #5 on: November 12, 2025, 09:17:19 AM »
No cable cutting required, but do take some pictures when taking apart, suprising how quick you forget. easy enough but fiddly.
CB500 1975
CB750F 1976
KLX250 1983
Lambretta SX200 1979
Mini Mayfair 1984
« Reply #6 on: November 12, 2025, 09:41:51 AM »
The kill switch needs to be desolded to remove it but the rest is straightforward.
Offline JezzaPeach
  • CB500/4 K1 1972 gold
« Reply #7 on: November 12, 2025, 10:54:24 AM »
Not sure but just wondering if one of those paint pens with the very small metal tip might help.
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
Offline neat street
« Reply #8 on: November 12, 2025, 10:56:54 AM »
No, tried and failed, the `paint` is not heavy enough to do the job, I used humbrel enamel model paint.
CB500 1975
CB750F 1976
KLX250 1983
Mini Mayfair 1984
Online Spitfire
« Reply #9 on: November 13, 2025, 09:59:02 AM »
I also used Humbrol enamel model paint on my switchgear, Humbrol 21 Gloss black on the switches and Humbrol 19 Gloss red, these come in 14 ml tinlets.
I took the switches off the bike and put them on a pair of handle bars and used my airbrush for the Black.
Once the black was fully dry a couple of days later the red was painted with a brush, excesss was wiped off with a cotton bud.
Note that some people say that the latters should be orange in which case it would be Humbrol 18 Gloss orange.
